Old 11-23-2015, 06:12 AM   #1
OswegoLion's Avatar
Red and Blue caps underneath in back end.
I was cleaning out my black and gray tank and when I looked underneath I noticed a blue and red cap line. I wasn't sure what they are for or hooked up to. I guess dealership didn't mention it.
OswegoLion is offline   Reply With Quote
Old 11-23-2015, 06:15 AM   #2
AquaMan's Avatar
Those would be your low point drains, for when you go to winterize. Enables you to drain most of the water from the lines.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 11-23-2015, 06:20 AM   #3
OswegoLion's Avatar
Thanks for whick tanks? I know water heater has its own drain.
Old 11-23-2015, 06:30 AM   #4
Low point drains are not for your tanks. They are for water left in your lines. Your fresh water tank will have it's own drain line as do your grey and black tanks.
Good luck,
Don
Don and Michele
3 Adult Children - 5 Grandchildren
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 11-23-2015, 06:37 AM   #5
Yep - low point drains. Assuming you are parked fairly level and assuming your unit was assembled with plumbing lines in a somewhat normal orientation, removing these caps (and opening faucets to release vacuum) will allow almost all of your hot (red cap) and cold (blue cap) water to drain out.
You probably have a third similar drain somewhere under there for the fresh water tank.
I was going to refer you to some good winterizing sites, but I see you are in FL so not sure what to recommend as I'm in the currently very cold Midwest.
The hot water heater drain that you mentioned is important too, but it is really only for the heater itself, not the rest of the supply and feed lines.
Happy Thanksgiving!
Brian
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 11-23-2015, 06:40 AM   #6
OswegoLion's Avatar
Yea Brian we are going north in May for 5 months. We may leave it there next when we return to Florida.
Old 04-29-2016, 10:24 AM   #7
OswegoLion's Avatar
Shoot those winterizing sites to me. I am in Upstate New York now and probably will leave 5th wheel here when I go back to Florida.
