Old 10-16-2014, 05:37 PM   #1
Relocating water filter: My solution
There have been several threads regarding removing the water filter(AKA Water Time Bomb) from inside the trailer. I wanted to share my solution (Flagstaff 21fbrs):
I installed two 1/4" threaded "U" hooks under the trailer, near the edge of the pass-thru floor. Fittings, a hose bib and quick-connects were added to the filter. QC fittings were added to the 4' hose and long supply hose.
The assembly hangs from the hooks when we are parked and setup.
I also moved the water pump closer to the door and added a protective cage made of wire shelving. I can monitor the pump and lines, and also access the valves thru cutouts in the cage.
So far I am happy with the setup.
Henboy is offline   Reply With Quote
Old 10-16-2014, 06:02 PM   #2
wbdavey's Avatar
Nice, simple and bullet proof.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 10-16-2014, 06:45 PM   #3
I'm thinking about moving my water pump to the other side behind the water heater on mine but haven't had time to investigate it.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
cat, water, water filter
