Removing dome over camper lights in a Flagstaff Microlite
Hello All
I am sure there is a thread here somewhere on how to remove the indoor plastic domes over the lights inside in order to clean the dirt that can be seen.
I would appreciate it.
Hello All
Thanks!!
Assuming you have the pancake type you slide them forward. You may have to gently squeeze the sides when sliding forward. Forward would be away from the switch.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
