Old 05-16-2016, 07:28 PM   #1
Removing factory stickers from new TT.
Just received our new Flagstaff 832 IKBS. Love this trailer so far. How do you safely remove all the shipping stickers from front of the trailer? Seems to be well adhered. There is also "Follow us on Facebook" sticker next to the ladder. Wow!
Name:   ImageUploadedByForest River Forums1463444687.283758.jpg
Name:   ImageUploadedByForest River Forums1463444715.650059.jpg
I would welcome any tried and true suggestions to safely remove these unsightly tattoos from the trailer.
Harlan & Pattie in MD
2017 Flagstaff 832 IKBS
2017 F-250 Crew 4X4 6.2L
MHBroker is offline   Reply With Quote
Old 05-16-2016, 07:37 PM   #2
Peanut Butter
Take some peanut butter (smooth not crunchy) dab some on the sticker and let it soak for 15-30 minutes. They will easily scrape off...
modemem is offline   Reply With Quote
Old 05-16-2016, 07:39 PM   #3
Cyber Phrenologist
Radio's Avatar
One of the magical properties of WD-40 is the ability to dissolve most adhesive used on paper stickers. Doesn't hurt most painted surfaces.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-16-2016, 07:43 PM   #4
Hair dryer to just warm them.
Old 05-16-2016, 07:49 PM   #5
heavynlori's Avatar
Some people peel them off and place in a binder for future reference....
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 05-16-2016, 08:37 PM   #6
Oh...these are definitely not willing to peel off easily.
Old 05-16-2016, 08:40 PM   #7
sgtlm17's Avatar
Wd40 or GooGone
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is online now   Reply With Quote
Old 05-17-2016, 03:04 AM   #8
Big Rig's Avatar
When mine was new all I needed was a hair dryer. I think because it was so new the glue was still fresh and all it needed was a little heat.
Big Rig is offline   Reply With Quote
Old 05-17-2016, 05:41 AM   #9
Mainframe's Avatar
Use a hair drier to warm them up, start at one corner and peel the decal,
As you heat the decal, too much heat will make it stretch thin and break, not enough heat will make it hard to lift, You have to practice, after you get the decal removed, you need Rapid Remover to get the glue off. Here is a link, this stuff smells like oranges.
http://www.amazon.com/dp/B006RU65UG/...0YAYJXWMEZ87TA
And as a side note, keep the bottle handy, this stuff removes a LOT of stains and marks on items that are hard to get off, like sharpy marks, shoe scuffs etc. whenever I am fighting marks on walls or anyplace, I grab Rapid Remover and it many times handles the job.
You know that glue on the new toaster oven that was left on after you removed the warning sticker? Comes right off, Stuff is expensive though.
2016 Shamrock 23WS
2018 F150 Ecoboost
Mainframe is offline   Reply With Quote
Old 05-17-2016, 06:53 AM   #10
PhoneDude 8289's Avatar
I used a hair drier on about 40 stickers on our RV and at a later time I removed decals and name from the front cap. The only sticker I place on paper for saving was the tire and load capacity sticker. FOB tires have been upgraded since. The hair drier worked well and a little acetone to remove any glue residue followed by wash and wax. (no ghost)
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 05-17-2016, 07:15 AM   #11
AquaMan's Avatar
WD40 and Googone wont generally work on metallic stickers, but will remove the left over adhesive. Hair dryer or heat gun (carefully), as others have stated, works best. The "peanut butter" technique is a new one to me, but would think it too, would only work on paper type stickers.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 05-17-2016, 07:27 AM   #12
jeff64's Avatar
X 2, may need a little WD40 on a rag to get the adhesive residue off
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-17-2016, 11:15 AM   #13
RiverPeeps's Avatar
I used a heat gun on low to warm and soften the decals, cleaned off the excess gooey stuff with wd 40 then put a good coat of wax on
07 Silverado Classic 2500 HD
15 Flagstaff 26fkws Emerald Edition
RiverPeeps is offline   Reply With Quote
Old 05-17-2016, 12:09 PM   #14
mike.t's Avatar
Sounds easy doesn't it.
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 05-18-2016, 11:21 AM   #15
Try a hair dryer on hight setting
Majicdoor is offline   Reply With Quote
Old 05-18-2016, 01:54 PM   #16
For those stickers that have warnings or information such as weights, take a picture before removals, download to computer files or print off and keep in a manual for future reference.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 05-18-2016, 02:11 PM   #17
x 2 on putting the pix into a folder. Or, if careful, peel and restick the label to the inside of a cabinet door. If vinyl cut letters, slowly peel off (the dealer name, etc) and throw away. The other? goo-gone or wd-40 and a quick wax afterward. I think I removed close to 20 stickers (the dealer advert by the back door really cheesed me - it was first to be gone).
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
2016251RKS is offline   Reply With Quote
Old 05-18-2016, 03:30 PM   #18
Usually Confused Member
emm-dee's Avatar
I took all the stickers off mine. Is there any way to have an "ordered" unit delivered with no stickers? If I ever custom order an RV I intend to ask for no stickers, no decals, etc. Just send it with a plain solid color paint scheme. Don't even want the model name showing.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 05-22-2016, 09:33 PM   #19
Thanks for all the suggestions. Will probably try a hair dryer...IF....it ever stops raining in Maryland.
Old 05-23-2016, 07:51 AM   #20
If the stickers with weight and tire information get damaged FR will send you new stickers. I got new ones from FR and keep them with the paperwork that belongs to the RV.
Joe & Beverly
2014 8289WS lifted
factory
