Old 01-02-2014, 07:36 PM   #1
Removing living room carpet
TOWTA is wanting to remove the carpet in the living room. Has anyone done this and how bad does it look from all the staples or nail holes? I think they lay the linoleum over the entire floor first and then the carpet.
Old 01-02-2014, 07:56 PM   #2
We had Min.carpet,but still came in the Bed room.Took it out and pulled staples around the doors. Since they build the walls and everything else on TOP of the Carpet I had to put quarter round in to give the Finished look. The only carpet is the Flap and small piece in the slide/livingroom area. Our unit has the Plank wood linoleum so staple holes are Not noticeable. Oh,(Suffer) in the Heat! Youroo!!
Old 01-02-2014, 08:02 PM   #3
Jack of All Trades
RJHuser's Avatar
OldCoot:
We did this before Goshen. Yes, the Linoleum was laid done first (also saw this in the factory tours), so the carpet can be removed.
As far as the staple holes, with our linoleum the holes blended in and unless you get down on the floor and look really hard they cannot be seen.
The hardest part was getting the carpet out from under the slide. There is a plastic strip that is over the carpet that has to be removed (and then reinstalled) before the staples can be removed. In our TT the slide comes very close to the wall with the entertainment center, and there were many staples in that area, and the carpet went under the wall - had to pull staples and cut the carpet at the same time to get a clean look.
One bit of advise - be very careful pulling the staples and be sure to get all of them. The linoleum is very thin and very easy to tear (I had one area, luckily it was under the flap of carpet on the slide, that tore a small amount. I repaired it with superglue.)
Over all it was an easy project. I started out away from the slide and worked my way towards the slide, cutting off sections of carpet as I went to keep the amount of carpet I had to work on down to a manageable amount.
Rick
(P.S. The carpet in the bedroom is just over plywood, no linoleum. I haven't decided what I will do with it)
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 01-02-2014, 08:02 PM   #4
Blaster 84's Avatar
We had our carpet replaced at Goshen last year. I wanted to leave the carpet off the non-sliding part of the RV. They wouldn't do that because as the slider moved in and out the over riding slide would leave marks on the linoleum. That being said I remember someone removing that carpet and noted the staple holes were not noticeable. They put down some sort of barrier to protect the linoleum when operating the slide.
2020 F250, 7.3 gas, 34 ft. Fifth Wheel, SOB
Blaster 84 is offline   Reply With Quote
Old 01-02-2014, 08:18 PM   #5
I have heard that about the slide, but our slide leaves no tell tale signs on the carpet as the slide lifts immediately when retracted.
Old 01-02-2014, 08:37 PM   #6
Jack of All Trades
RJHuser's Avatar
We've only opened/closed our slide maybe ten times since the carpet has been removed and don't see any sign of scrubbing or rubbing on the linoleum. Like yours, OldCoot, the slide lifts as soon as it starts out/in.
Rick
Old 01-02-2014, 09:28 PM   #7
Rick
Thanks, IF, TOWTA suggests it again, I will remove the carpet immediately so she can't change her other mind again.
Old 01-03-2014, 12:51 PM   #8
When it warms up tomorrow, out goes the carpet according to TOWTA. (It may come out today while she takes a nap. )
Old 01-03-2014, 12:55 PM   #9
Herk7769's Avatar
Do you recall what they charged for replacing the carpet?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 01-03-2014, 01:53 PM   #10
Blaster 84's Avatar
No charge.
Old 01-03-2014, 01:59 PM   #11
Herk7769's Avatar
Love it!
Old 01-03-2014, 02:18 PM   #12
Dave_Monica's Avatar
Our 8280WS was ordered with minimum carpet, but I removed the carpet apron in front of the slide. You'd have to get on your hands and knees to see were the staples were.
I kept two pieces of the carpet I removed to put down on the lino at each end of the slide before bringing it in.
Dave
ID:	44425   Click image for larger version
Old 01-03-2014, 03:17 PM   #13
Dave
Dave your Pics show the same (Flap) in front of the slide as we have? Where are the removal Pics? Youroo!!
Old 01-03-2014, 04:52 PM   #14
Well, the process has started. Dulled my carpet knife, so now off to Lowes for replacement blades. Lots of staples to remove from the super thick 3/8" foam rubber pad. (What a joke) TOWTA is starting to smile.
Name:	Partially removed carpet.jpg
Old 01-03-2014, 05:11 PM   #15
The 'before' picture...
Old 01-03-2014, 05:38 PM   #16
wfmdfm's Avatar
OldCoot you plan to remove all the carpet even on the slide? If so I would love to see the pictures of this project. How will you cover the seam where the slide joins the floor? We have been looking this project over but were unsure of how it would work out.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 01-03-2014, 09:57 PM   #17
Wally
Not planning on removing the slide carpet, but I have toyed with the idea of adding underlayment and hardwood laminate and just rabbit out a custom made threshold on the back side and taper the front side. We'll see how this turns out when we get the carpet out.
Name:	In progress 2.jpg
ID:	44442   Click image for larger version
Name:	TOWTA @ work too.jpg
Old 01-03-2014, 11:11 PM   #18
Finished, finally. Not an easy job, but TOWTA is HAPPY, HAPPY, HAPPY, so all is well. We'll see how long it is before she wants laminate flooring put down.
ID:	44444   Click image for larger version
Old 01-03-2014, 11:18 PM   #19
RKR
RKR's Avatar
Looks great OC. Nice job.
RKR is offline   Reply With Quote
Old 01-04-2014, 01:55 PM   #20
Camper Less Camping
Cajun Po-Boy's Avatar
Looks good
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
roo
