Old 07-23-2013, 08:53 PM   #1
Removing Silicone from side/fiberglass
Is there anyway to remove old silicone from the side? The dealer moved the scare light and you can see the remnants of the outline of where it was because of the silicone. I tried using a plastic putty knife but it is very stubborn. Also it looks like the dealer possible used some rubbing compound and dulled the shine...
kamper00 is offline   Reply With Quote
Old 07-25-2013, 11:39 AM   #2
When silicone cures, it is a task to remove. Try using a hairdryer to heat it up and carefully remove as much as possible with your plastic knife. Residue can usually be removed with rubbing alcohol or paint thinner, but wash immediately. A good carnuba (sp?) wax should restore the shine.
2014 Flagstaff 27RLWS
2004 Chevy Avalanche 2500
1998 21' Thor (doesn't everyone need 2 TT's?)
eshenderson is offline   Reply With Quote
