Old 05-20-2018, 05:55 PM   #1
Removing Water Filter
For those that removed the water filter: did you need to add more tubing or were you able to pull the 2 tubes closer? Also, what connector type did you use?
Thanks in advance
2018 Flagstaff Micro Lite 23LB
Equalizer 4 PT. WDH 1k/10k
2012 Jeep Grand Cherokee V8 4x4
jk70 is offline   Reply With Quote
Old 05-20-2018, 06:39 PM   #2
slide5r4fun's Avatar
I just used a 6 nipple from Lowes to connect the two lines. Also added garden hose fittings to the filter housing. Ill just set the filter in a crate under the camper so its easily accessible.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
slide5r4fun is offline   Reply With Quote
Old 05-20-2018, 06:58 PM   #3
Attachment 172651
Attachment 172652
Thanks. I have Pex pipes (I think) but this should help
Old 05-20-2018, 07:10 PM   #4
Sharkbite fittings seem to be a popular solution for Pex line mods. Unless you or a buddy have a Pex crimping tool, I would probably go that route.
Kevin & Janine
Old 05-20-2018, 10:09 PM   #5
Kasual Kamper
What's the harm in just leaving the filter housing connected without a filter? Yes, removing it is cleaner, but mine is hidden behind a panel anyway.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is online now   Reply With Quote
Old 05-20-2018, 10:32 PM   #6
SailorSam20500's Avatar
If you need to winterize the rig, that canister holds quite a bit of anti-freeze. Also, it prohibits winterizing by just blowing out the lines - you won't get the water out of the housing and it will freeze and break.
Al
Save the Earth. Its the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is online now   Reply With Quote
Old 05-20-2018, 10:40 PM   #7
WFD
Plus they are notorious for leaking, so just removing the filter itself and leaving the housing in place does not resolve the issue they have for coming loose and leaking.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-20-2018, 11:19 PM   #8
I had lots of slack. Just put in a 1/2" PVC coupler.
Name:	Filter replacement coupling.jpg
ID:	172731   Click image for larger version
Name:	half inch DURA coupling.jpg
2011 Traverse LT, 3.6L, FWD
Old 05-21-2018, 07:49 AM   #9
jeff64's Avatar
I cut the white outlet hose from the filter just close enough to get a smooth bore in the tube. I cut off the band clamp at the "T" fitting with a dremel and cut off disc . I carefully peeled off the short piece of PEX tubing with a pocket knife so not to damage the barbed fitting. Put the white tube on at the "T" with a new ear clamp and crimped in place. Leak check it. Parts needed: 1 new ear clamp.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-21-2018, 09:26 AM   #10
Kasual Kamper
Thanks, I used the "soda bottle to take up space" method last fall to minimize the amount of the pink stuff occupying the filter. I also blow out the lines beforehand.
Old 05-21-2018, 11:15 AM   #11
I've decided to leave mine as is. I plan on using my TT during freezing weather and have had one day already with freezing weather in a campground (May 2 in N Utah). Putting the filter outside would be a disaster in these situations so I am leaving it right where it's nice and warm.
As for blowing out the lines to winterize, I just removed the filter and dumped out the canister. The canister holds about a quart of pink antifreeze which in the grand scheme is no big deal. Just dump it out before flushing lines in the spring (unless keeping heat i trailer all winter and using it frequently).
One could merely buy a couple valves like those used to bypass the water heater and bypass the water filter for winterizing. Set valves in bypass mode, remove filter, dump canister, and don't give it any more thought until spring.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-21-2018, 01:05 PM   #12
Kasual Kamper
I think the issue for many of us is the ridiculous price of the proprietary KW1 replacement cartridges vs. a standard filter as evidenced in this thread. I think I'm going to leave my filter in place without a cartridge and install an outside filter that uses standard cartridges.
Old 05-21-2018, 01:24 PM   #13
It might be nice and warm, but that doesn't mean it won't fail, as many other's have failed. Good luck.
water, water filter
