Old 03-20-2019, 03:02 PM   #1
Replacing tires on a 2016 26RLWS
We will be replacing our tires soon. I want to make sure the service center doing it lifts the RV correctly. I've seen several threads but wasn't sure if my specific model was different. Does anyone have experience with how the shop should lift the RV to change the tires? Thank you in advance.
2015 Chevy 2500HD
2016 Flagstaff 26RLWS
2016 Apricot Labradoodle "Lilly"
dugwms is offline   Reply With Quote
Old 03-20-2019, 09:42 PM   #2
dbledan's Avatar
I have same trailer but have not jacked it up without a trailer aide once so far.
What tires you planning to put on it?
dbledan is offline   Reply With Quote
Old 03-21-2019, 08:21 AM   #3
Goodyear Endurance. Moving up to load range D.
2015 Chevy 2500HD
Old 03-21-2019, 08:48 PM   #4
TRD
Just changed out 4 Castle Rock tires for Endurance ST's on my Flagstaff 25BDS. I was on my way from MI to SC and had a puncture to sidewalk on Castle Rock..unrepairable. Put on spare in Nashville Koa. Replaced with 4 Goodyear's n Beaufort SC. I used my Trailer Aid tire ramp at the dealer because I didnt want to take chances with my torsion axles. Plus, they didnt have a jack to reach frame. Dealer was great! Got all 4 done in 30 min or less. I moved trailer on and off ramp as they changed the tires. $125 each installed. I also used ramp to change tire in Nashville. It's a must have item in your repair toolkit.
2018 Micro Lite 25BDS
2018 Ford F150 XL LB 2.7 EcoB
Lake MI Bi-boater (Sail and Power)
TRD is offline   Reply With Quote
Old 03-22-2019, 12:19 PM   #5
Canadian Member
Tell them to jack on the frame, not any part of the Dexter Torflex axles. Pick a spot on the main frame in front of or behind the axles.
Good call on going up one load range. Sometime in 2017 (I think) the RVIA changed their recommendations on tire load ratings and the manufacturers started installing tires with a higher load rating, so new ones today are more likely to be adequate for loads that people actually put on their tires.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 03-22-2019, 01:30 PM   #6
Canadiancrew's Avatar
May I ask what size the new D's are. I have a 2016 27RLWS and it has 205 75 14's. I do not believe there is an room to go bigger. I assume you have the same size and hoping they would be available in a D load range. We just got back from Arizona and California and put at least 5000 miles on my tires that had at least 20K on them already. I am looking to replace them before another major trip.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 03-22-2019, 01:36 PM   #7
dannyabear's Avatar
The Endurance is 'D' rated, uses 65 psi; great tires been running mine for about 14 months now;
Change valve stems also
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-22-2019, 03:12 PM   #8
Endurance E rated 10 ply 235X80 Seems to be a great tire.
Portagie1968 is offline   Reply With Quote
Old 03-22-2019, 03:23 PM   #9
That won't fit these trailers.
Orval and Yvonne
Old 03-22-2019, 04:43 PM   #10
Tundra 2014
Tires
Wise to be concerned. I use an Anderson drive on jack. Highly reccomend it. When I changed my tires to GY Endurance, I took ramp to the tire store w/ me and was driving it up for each tire change. The tech got in a hurry and put a jack under the support behind the axel. W/O me knowing, bent the support. After about 1500 miles on a 3500mi. trip, I realized the wheels were not inline when I turned in for gas. I had a new thicker support bar welded in when I got home at a trailer repair shop. I have the Dexter rubber hub axels, I do not see any good place to put a floor jack under it. WATCH THEM!
Tundra 2014 is offline   Reply With Quote
tire, tires
