Old 08-16-2014, 10:04 AM   #11
Originally Posted by dan-nickie View Post
Switch the water heater to LP and I'm sure your problem will disappear.
Hmmm ... So Dan, are you saying that with my water heater on gas, and the AC compressor on, the breakers should not trip when the microwave is turned on high power? I that is the case I may well do the experiment on this trip. If I do I will report back on the findings.
Seems like two workarounds - (a) no AC compressor on, vs (b) LP gas and no electricity to the water heater.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 08-16-2014, 10:13 AM   #12
dan-nickie's Avatar
That's the way my last 30 amp RV worked.
It just takes a few seconds to switch the water heater to LP and test.
What do you have to lose?
From the chart someone linked to:
Air Conditioner (X number of A/C) 12-16 Amps
Electric Water Heater 9-13 Amps
Microwave 8-13 Amps
Any 2 adds up to LESS than 30 amps.
All 3 WILL trip some breaker.
Your choice on which 2 you want to run at once.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-16-2014, 11:50 AM   #13
I've tripped the breaker on the 30 amp pedestal a couple of times by running the AC and microwave at the same time. Microwaves draw quite a few amps. No big deal. Just go outside and flip it back on. It's nothing to worry about.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 08-16-2014, 12:21 PM   #14
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
I dont use the hair dry for the same reason... turn off the A/C and/or the microwave. Trailers are NOT like your house!! Besides... its called "camping" for a reason... you have to give something up.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 08-16-2014, 05:17 PM   #15
thetiler's Avatar
When I set up I try and setup my outside cooking appliances with a 110 to the pedestal
I use a 1500 watt griddle outside and that seems to blow the breaker a lot
2013 F350 SB,CC Lariat Ruby Red,3.73Gears,5Star Tuned,,Line-X Bed,Extang Platinum Cover,Airlift LoadLifter 5000 Bags,Airlift Wireless Air controller,Reese Signature Series Fifth Wheel Rail Kit,B&W Fifth Wheel Hitch,2014 Flagstaff 8528BHWS
thetiler is offline   Reply With Quote
Old 08-16-2014, 06:17 PM   #16
Thanks but it looks like I have another problem - I never used the WH on gas ever since taking delivery (at the PDI) and I just switched the rocker switch on the WH to OFF (was on for the electric) and then switched the inside control panel switch to ON and noticed that the little red LED labelled "DSI/FLT" did not come on. I went to the WH outside and noticed that the burner did not light. Hmmmm ... read the instructions on the WH itself and it suggested that the rocker switch on the WH had to be ON so I did that - now both the onside control panel switch was ON and the rocker switch was on. The burner did not ignite and the "DSI/FLT" light was still off. I shut it down again.
Got out the manual and it seems that the DSI/FLT illuminates when the burner fails to light so no light at the start is okay.
What am I missing here?
Regards,
Wayne
Old 08-16-2014, 09:26 PM   #17
Slympicins's Avatar
Wayne I haven't run mine on gas yet either. Let me know what you get after you pioneer the way.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Slympicins is offline   Reply With Quote
Old 08-16-2014, 09:51 PM   #18
onetonford's Avatar
When water in heater Is cold and you turn on the gas switch the lite comes on till it lites if it don't then it tries to lite three more times if it don't lite then it will stay on telling you it failed to lite. to reset you just turn switch off and back on and it will try again. If the water in the tank is already hot from the electric element when you turn on the switch inside for gas it won't come on because water is already hot and until it cools down then it will go thru it cycle to lite and heat water.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-16-2014, 10:04 PM   #19
Onetonford - Thanks for the info. My water was already hot from the electric element so it makes sense if it does not come on. I have left it on for the past few hours and the water is still hot so I assume that the gas burner is working. I will update tomorrow morning.
Regards,
Wayne
Old 09-06-2014, 01:18 PM   #20
Back to the MW for a minute, could running the MW and AC together cause the MW to be damaged, somehow? Forgot to turn AC off while heating dinner last night and the MW stopped working. Breaker didn't trip, but the MW is dead as can be.. I pulled it out, and the outlet has power...
Thanks!
B.
2008 Forest River Micro-Lite 18FBR
2000 Ford Explorer Sports Trac
WBrian is offline   Reply With Quote
breaker
