Old 09-28-2018, 08:37 AM   #1
Dmax07's Avatar
RV Pedestal Electrical Connection
What do you use to achieve a good connection at the RV electrical pedestal dielectric grease, conductive grease or other to prevent arching and corrosion of power cord terminals?
Dmax07 is offline   Reply With Quote
Old 09-28-2018, 08:41 AM   #2
Professional Curmudgeon
wrvond's Avatar
I keep the prongs on my connector clean and turn off power at the pedestal until the connection is made then turn on the breaker. I also turn off the power before unplugging. No arcing that way.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 09-28-2018, 08:44 AM   #3
Jim34RL's Avatar
X2, I have done this for the last 40 years with all of my trailers. Never had an arcing issue.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 09-28-2018, 08:44 AM   #4
007matman's Avatar
What they said..
007matman is offline   Reply With Quote
Old 09-28-2018, 09:12 AM   #5
rsdata's Avatar
cleans and protects all your electrical prongs, even on the TV/trailer
better than contact cleaner...
2014 Shamrock 183
Old 09-28-2018, 09:25 AM   #6
nothing
The Turners...
formerFR is offline   Reply With Quote
Old 09-28-2018, 01:08 PM   #7
As the others have said, keeping everything clean and making sure the power is off before plugging in or disconnecting is essential. I use a light coating of dielectric grease on the prongs to help prevent corrosion between uses. We also carry a 50 amp to 30 amp dog bone adapter so we can use the 50 amp receptacle if the 30 amp receptacle is worn - I think the 30 amp receptacle gets more use and runs closer to it's full amperage at a lot of parks.
Cathcartww is offline   Reply With Quote
Old 09-28-2018, 06:40 PM   #8
Agree with all and one more step before turning breaker on at the pedestal, plug in pull out plug, plug in pull out 3 - 4 times it helps to make a cleaner connection with the pedestal that may tarnish slightly - cleaner contacts, less resistance, less heat - No arching!!
fvhotrod is offline   Reply With Quote
Old 09-28-2018, 06:44 PM   #9
Yep. The most important thing is to shut the breaker off then plug in. I use di-electric grease on all electrical connections.
HAPP is offline   Reply With Quote
Old 09-28-2018, 06:59 PM   #10
Retired Member
RMWSierra's Avatar
I use Noalox made by Ideal. Found at Home Depot.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
RMWSierra is offline   Reply With Quote
Old 09-28-2018, 10:43 PM   #11
dielectric grease is NON-conductive and its only purpose is to seal out moisture and prevent corrosion on connectors. It will not allow for a better electrical connection.
TranceX2 is offline   Reply With Quote
electric, electrical
