Old 01-28-2013, 02:44 PM   #21
kfp673's Avatar
Sounds good. Couldn't you just work around the toilet and use a piece of flexible molding to hide the cuts? My vision was just to jig saw the wood floor around the toilet and not move it at all. What are your thoughts? So the 3/8" flooring was thin enough for the slide to glide over it with no problems? And if I read it right your floor is just floating correct? You did not glue it for nail it down at all? Thanks again for the info! As for the pics, just post any that you have. More detail for us the better. Thanks!
kfp673 is offline   Reply With Quote
Old 01-28-2013, 02:54 PM   #22
kfp673's Avatar
Also one more thing. How will you do T molding in the rounded area towards the front of the camper where the carpet and laminate wrap around to the outside door? Obviously you can cut the flooring to be rounded but how would you do the molding? As you can tell I am not a floor expert. Thanks again
Old 01-29-2013, 02:57 AM   #23
johnymoto's Avatar
tee molding pic's
here's some pics of the tee molding and the finished look.Click image for larger version
johnymoto is offline   Reply With Quote
Old 01-29-2013, 07:59 AM   #24
kfp673's Avatar
Gotcha, so the answer to my question above is around the bend you used metal T molding and it looks like you just creased it a bit to make the turn is that correct? Hate to keep asking for pictures but I would love to see 2 full shots now that its done. One standing by the bathroom and one from the front door just to see the finished look of the entire floor. Thanks again for all the feedback and pics, it's been a big help!
Old 01-29-2013, 11:36 AM   #25
johnymoto's Avatar
pic's
ill get more pic's for you today. the t molding i cut with tinsnips and used scrues to hold t molding in place. i found out it;s better to put the t molding in place before you do the wood. then you can cut them perfict my bad. i dident put any felt down that you put under the wood because of the height of the wood concerns of being to high. the main thing is keeping the wood low as posable so the slide out wont drag across it and scratch it .
Old 02-03-2013, 01:49 AM   #26
johnymoto's Avatar
here is the last pic's very happy hope i gave enough info. found out it's better to start putting down t molding strip first.
ID:	23817   Click image for larger version
ID:	23818   Click image for larger version
ID:	23819   Click image for larger version
ID:	23820   Click image for larger version
Old 02-03-2013, 04:16 AM   #27
Witch Doctor's Avatar
That looks great, such things make great improvements and I'm sure it will be a lot easier to keep clean, We seem to always be cleaning our rug. Plus will supply some extra strength. Nice job
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-03-2013, 11:19 AM   #28
johnymoto's Avatar
thank you
Old 07-08-2013, 09:38 PM   #29
kfp673's Avatar
I know this is an old thread but I'm about to do this same job to my 06 831 BHSS and want to get it right. Johnny can you confirm you used 5/8" manufactured flooring? 5/8" is not to thick for the slide? Thanks again
Old 07-10-2013, 09:09 AM   #30
johnymoto's Avatar
3/8 is short the 5/8 is to tall
