Old 09-17-2012, 05:51 PM   #1
johnymoto's Avatar
sagging floor
sagging floor buy the heat vents. is this a problem with the supports under the floor of a 2007 flagstaff 831bhss. and there close by the door.and no water leaks ever around their.
johnymoto is offline   Reply With Quote
Old 09-17-2012, 07:52 PM   #2
kfp673's Avatar
I have 2006 same model and the floor is soft in many places but around the vents are indeed very soft.
kfp673 is offline   Reply With Quote
Old 09-17-2012, 11:38 PM   #3
johnymoto's Avatar
is there anything i can do about it. is there a support that has fallen down.
Old 09-20-2012, 06:14 PM   #4
install a hardwood floor over the old floor ... solves the probelm for ever.
Gatekeeper is offline   Reply With Quote
Old 10-28-2012, 09:12 AM   #5
kfp673's Avatar
That's not a bad idea but how would you do this and still allow enough room for the slides to come in and out?
Old 10-28-2012, 09:12 AM   #6
kfp673's Avatar
That sounds like a great idea but how would you install a hardwood floor and stil allow room for the slides to come in and out??
Old 10-28-2012, 10:21 AM   #7
johnymoto's Avatar
i checked it out at the wood floor place you have to get the thinnest wood floor to make it work it cant be anymore higher than the carpet. i believe its engineered wood .
Old 11-03-2012, 01:41 PM   #8
Ret E-9 Anchor-clanker
donanddona's Avatar
Talked with the factory rep at Forest River. Thge hardwood floor can be 3/8" in hieght. Although he did advise running the boards lengthwise to ensure support. If you remove a resister and peel back the alumimum tape you will see how the floor is constructed. Styrofoam sandwiched between two very very thin pannels... this compacts over time and does not provide proper support.....
donanddona is offline   Reply With Quote
Old 11-03-2012, 03:35 PM   #9
johnymoto's Avatar
and they wont stand behind their product. and if you have carpet close to it you have to use a rubber strip that clicks under the carpet and clicks to the wood floor and your right about the layout of the wood. and i was told you cant do it in the bathroom because of the flange under the toilet is this true.?
Old 11-03-2012, 03:47 PM   #10
Camper Less Camping
Cajun Po-Boy's Avatar
Thank goodness for this forum and issues like this coming up in conversation because we almost bought a Flagstaff 5'ver with this type of floor until reading threads like this.
I stayed clear of this type of construction when shopping for our new fifth wheel knowing I'd have a fit when these issues surfaced.
Good luck!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
