Old 09-20-2008, 10:12 AM   #1
nomoreosama's Avatar
Seperate Galley/Grey Tank
Anyone else have a separate galley tank? I have a 2008 829BHS, where my galley tank drain is under the slide out and my Grey/Black tank drain is near the rear of the trailer. Has anyone devised a way to empty these tanks while utilizing a "Y" so can just use one (main) sewer line when emptying these tanks? More like running a drain line from the galley tank, then have that line go to a "y" and meet the Grey/Black sewer line, ultimately ending in the sewer line? I hope you understand what I am asking?????
The problem is, reaching the galley tank drain while the slide out is extended....You have to go underneath the slide out to hook-up and drain.....
I am glad my wife is small.....she can fit right under the slide out and drain it with no problem....I am more than willing to do it when the slide out is in.....
Any ideas would be appreciated....
Wally
nomoreosama is offline   Reply With Quote
Old 09-20-2008, 05:11 PM   #2
jmyers's Avatar
You might try something like this:
http://www.campingworld.com/shopping...nnection/31209
My driver's license says my name is "Jeff"
2000 Chevy 2500 4/4 6.0/3.73
2002 FR Sandpiper 30FKSS
Reese Strait-Line
Prodigy
DW
DD (Darling Dachshund)
jmyers is offline   Reply With Quote
Old 09-20-2008, 07:56 PM   #3
Cyber Phrenologist
Radio's Avatar
I have a seperate galley on my Rockwood 5th wheel.
Go get something like this Valtera 3" cap (this one from Camping World) And one of these sewer elbows (this one from RVWhosalers). Note the attachment for the garden hose you just run between the two.
No muss. No fuss. No extra sewer hose or bulk "Y" to lug around.
Easy.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-20-2008, 08:10 PM   #4
Radio, I like your thinking.....easier that totin' a "Y" around and extra hose and then a slunky and so forth.....
Wally
2008 Flagstaff 829 BHSS
Reese Dual Cam Sway Control
2008 GMC Sierra 2500 Duramax
Old 09-21-2008, 06:38 AM   #5
HookupAndGo's Avatar
I think what nomoreosama is saying is that having to climb down under the slide to open/shut the valve is a pain... and I agree. I like to keep my galley tank closed so that when I do open it up, any food particles etc go out with the mass rush of water.
So, if I understand correctly, he (and I) are both wondering if anyone has done anything to basically "connect" the galley drain to the back where the other 2 tanks drain? That would allow for one location to open/close the tank valves.
Still can't figure out why they would put that valve right under the slide....just to save a couple bucks and run the dump back to the back....
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
HookupAndGo is offline   Reply With Quote
Old 09-21-2008, 01:05 PM   #6
Cyber Phrenologist
Radio's Avatar
I understand all that...but I am not one to do major surgery on my trailer.
It is a goofy location to put the gally drain under the slide. We do a lot of state park camping with no sewer and when we get to the dump station the slide is in so that's no big deal for us. But for those rare times we have full hookups, I like the garden hose method.
Also, we use a food strainer that sits on top of the drain to minimize food bits in the gally tank, (not just the little basket that goes in the drain) and we treat the galley with chemicals and laundry soap the same way we do the black.
This works for us, it's easy and cheap.
KU4OJ
Old 09-21-2008, 02:49 PM   #7
First off, I have used a simple solution similar to Radio's for the past two season's on a seasonal site with no problems.
Milzat did re do his plumbing to combine them into one drain. Here is a link to what he did.
http://rocky06fs.forumco.com/topic~TOPIC_ID~1064.asp
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 09-21-2008, 09:53 PM   #8
"Y"
Several trailer supply houses have the "Y" in stock. The will attach at the sewer dump. It works!
Life is something to do when you've finished breakfast
Chuck & Margie
Both Retired
08 2500HD Silverado 6.6L Duramax
Flagstaff 829fkss
Round Mound of Sound is offline   Reply With Quote
Old 09-22-2008, 06:45 PM   #9
Thank you all.....I greatly appreciate ALL of your help.....I am not ready to do surgery on her, so I will use "Radio's" idea.....sound's the easiest and fastest.....Plus I do not want to deal with all the other "y"'s and sewer hoses.....
Wally
Wally
flagstaff
