Originally Posted by OldCoot
For the ones under the bumper, I used a 1" sq tube with tabs on the ends and a 17/32" dia hole in the center and drilled a 17/32" dia hole in the frame flanges and used 1/2" thd'd rod with nyloc nuts to hold them. The other round tubes I mounted with aluminum straps and 1/4" self tapping sheet metal screws thru the straps.
OldCoot,
I have a Solera and using the PVC fence post I only have a lttle over six inches of ground clearance.
Do you have more clearance? I'm worried that 6" is not enough ground clearance? Anyone else share my concern?
