Old 06-19-2012, 06:48 PM   #1
sewer smell
Used our 2006 30 foot flagstaff 5th, for the first time, dumped the sewer and when we got home the smell inside the trailer was terrible. then again when the wind was blowing yesterday, went out to the trailer, open the door and again the inside smelled of sewer. Anyone else have this problem, I did check stack at top and not plugged Thanks Irv
iducher is offline   Reply With Quote
Old 06-19-2012, 08:06 PM   #2
bikendan's Avatar
did you leave the black tank empty!!
if so, you are NEVER supposed to do that.
you always add back 3-5 gallons of water and whatever tank additive you've been using.
Old 06-19-2012, 08:24 PM   #3
Herk7769's Avatar
Remember also that gray water smells bad too.
Travel sloshes water out of the traps and lets sewer gas (from decomposing grease and food) into the camper.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 06-19-2012, 09:06 PM   #4
Grape Escape
Check under sinks for vent valves. If these go bad stink from gray water is awful. Can't believe manufacturers get away with this shortcut. Easy to replace as they are screw in and available at most hardware stores. I always carry a spare.
My theory is if you open drain valves the seal is broken to allow air to vent and they don't reseal due to age or poor sealing surface the stink begins. Once I replace them the stink is gone. 10$ 2 minute fix.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 06-27-2012, 10:18 PM   #5
also dont leave the black and gray water gate valves open... the ones you pull to dump the waste...push those back in.
Brad & Melissa
2002 Ford Expedition 4X4 4.6 ltr
1999 ForestRiver Flagstaff 829BHS
braddaddy is offline   Reply With Quote
led pad
