Old 05-08-2017, 07:17 AM   #1
mt_creative's Avatar
Shower head Clips and hose.
I was switching out the main shower unit this weekend and notice there wasn't any silicone around those fasteners.
I'll be adding some myself and re-screwing them to the walls. Seems like a no brainer to me that it should be sealed tight. Especially on the main wall that will get drainage from the shower head. It is just two screws with those plastic mounts which will certainly leak over time. Click image for larger version
ID:	137122Click image for larger version
mt_creative is offline   Reply With Quote
Old 05-08-2017, 07:48 AM   #2
SeaDog's Avatar
I approach these fittings the same way I do when installing a window in a house. I seal the top and sides and leave the bottom open to ensure should any water get in there it drains. I also put sealant in the screw holes.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-08-2017, 08:02 AM   #3
jeff64's Avatar
This would probably be a reasonable application for a piece of butyl tape and it will seal the screws. Seadog's comment on the space for water drainage is pretty "right on" especially if the left photo is applicable for what you are doing although that concept may not work with silicone as well since it will thin out
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-08-2017, 08:02 AM   #4
NMWildcat's Avatar
Before we use any shower in a new rig I re-caulk the whole shooting match, including the glass doors. Haven't seen one yet that didn't leak from the factory
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 05-08-2017, 03:28 PM   #5
DouglasReid's Avatar
We have a hose holder (ring) midway up the side of the shower like that one has. We did not like it. It did not allow the want to be used easily.
My solution is simple, I cut out the round part beginning at the back and made a slot on the side of the ring to allow the hose to come out of the ring. This way we can use the wand to wash and yet it still stays in the ring while traveling.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 05-08-2017, 03:36 PM   #6
Great mod.
I've done this on my last 4 units.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 05-09-2017, 11:49 AM   #7
OscarsMom2's Avatar
Could you please post a photo of this mod? I have always removed the shower head and taken the hose out of that ring. When traveling, I just put the shower head on the shower floor. I like your idea better than what I've been doing.
2020 Rockwood 2608BS
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
Old 05-09-2017, 06:25 PM   #8
Sure, it will take me a couple days though because Im traveling for work and am not home.
Old 05-09-2017, 07:23 PM   #9
OscarsMom2's Avatar
Thank you. There's no big rush.
Old 05-10-2017, 10:55 AM   #10
I'm a visual person, so a photo would really help me too I have all summer to figure out how to survive in this thing.
I don't quite understand why this clip was even necessary but I suppose the road bumps knock this out of the top holder and the ring then catches it from falling and cracking on the floor?
All these little tweaks are an interesting piece of the TT adventure. TIA for all your help!
Old 05-10-2017, 02:17 PM   #11
NMWildcat's Avatar
I never understood the purpose of the ring either. For us, it just limited the movement of the shower head hose to make it difficult to use
On our last 4 rigs I just completely removed the ring and caulked the holes.
Our shower head has never bounced out,but all of our showers are toward the front of the trailer. Maybe that means less bounce.
Old 05-11-2017, 05:06 AM   #12
Here you go. Hope this helps!
Old 05-11-2017, 05:50 AM   #13
Interesting. So when you shower you simply pop it out of the ring to make it easier but this still holds it in place for whatever reason while you're traveling?
Old 05-11-2017, 06:39 AM   #14
Can't wait to see photo too...
J007 is offline   Reply With Quote
Old 05-11-2017, 06:54 AM   #15
Exactly!
show, shower
