Old 06-02-2015, 06:31 AM   #11
Stormrider151's Avatar
Originally Posted by Jim34RL View Post
I install four screen plastic clips that can be rotated, that are mounted into the present screws that hold skylight in at the corners. We then mounted a 1/4 thick white foam cut to fit the clips. The foam board can be purchased at a craft store, clips can be purchased at a local hardware store such as an Ace hardware in the storm door repair parts area. I did this for under $5.00. The board is removed for showering and than reinstalled.
I did the same thing. Works very well. I have two skylights and with the sun coming through the ac just couldn't keep up. This solved the problem.
Stormrider151 is offline   Reply With Quote
Old 06-02-2015, 02:36 PM   #12
shower sky;ight
I used a paper accordion shade from Home Depot and a pice of plastic. It was sunny when I took the pix.
ID:	78865   Click image for larger version
hapecmpr is offline   Reply With Quote
Old 06-03-2015, 07:07 PM   #13
Jim34RL's Avatar
Originally Posted by Aggie_90 View Post
Do you have a pic you can posts? TIA!
I see if this will attach to this thread.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 06-06-2015, 05:21 PM   #14
I applied a film to the underside of the skylight. Bought the film (it reduces u.v. penetration) from one of the big box stores. This still allows light, but seems to have reduced the "heat".
2010 Flagstaff 8528RKWS
2009 GMC 2500
tom.keith is offline   Reply With Quote
Old 06-06-2015, 06:10 PM   #15
geezer with gadgets
757Dave's Avatar
We are also interested in doing something similar (just not sure what right now.) Was wondering about the outer skylight distorting or cracking from the reflected heat. Anyone notice a problem with doing this sort of mod?
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is online now   Reply With Quote
Old 06-06-2015, 06:54 PM   #16
Cyber Phrenologist
Radio's Avatar
My exterior bubble cracked and leaked due to sloppy installation at the factory. When I changed it I went back with a smoked tint bubble. Read about it here.
D-I-Y Shower Skylight Bubble Change
But before that I was roasting in the summer heat and wanted to sleep a bit after sun up, so I took down the inner "garnish" and just put a piece of parchment paper over the little window in the garnish.
Cheap fix, about 10 minutes, helped a lot. And it didn't mess with the outer bubble.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
show, shower
