05-30-2015, 08:03 PM
Shower skylite
We have a8528 Flagstaff with a clear shower skylite. How do other Flagstaff owners block the heat it lets in? Or any one else with clear skylite.
Thanks for your help.
05-30-2015, 08:07 PM
I just saw this today (not for the shower) but it's a insulator for vents. I purchased it to keep the light out of the bedroom.
Camco 45192 Sunshield Vent Insulator with Reflective Surface
http://www.amazon.com/gp/product/B00..._detailpages01
05-30-2015, 08:25 PM
05-31-2015, 08:46 AM
Originally Posted by NoviBill
On our Rockwood, the shower skylight frame is exactly the same size as the frame for the frosted glass in the door and the reflective shade for a door covers perfectly.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
05-31-2015, 09:31 AM
I install four screen plastic clips that can be rotated, that are mounted into the present screws that hold skylight in at the corners. We then mounted a 1/4 thick white foam cut to fit the clips. The foam board can be purchased at a craft store, clips can be purchased at a local hardware store such as an Ace hardware in the storm door repair parts area. I did this for under $5.00. The board is removed for showering and than reinstalled.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
05-31-2015, 09:47 AM
I don't have a Flagstaff but in mine, which has an odd-shaped skylight, I bought a thin piece of clear plastic and cut it te same size as the frame. Then I got a paper light blocking folding shade at Home Depot and cut that the same size. I used the screws from the frame to hold it in.
05-31-2015, 09:52 AM
Who Dares, Wins
Well that just seems like an easy fix. I think I have my next project... Thanks.
2015 Chevy HD D-Max
2022 Impression 315MB
06-01-2015, 03:12 PM
Do you have a pic you can posts? TIA!
2015 Flagstaff 29FBSS
Camping: 2016 - 22 days so far and lots more scheduled; 2015 - 40 Days, 2014 - 20 days
06-01-2015, 03:31 PM
I'll get one tomorrow
06-02-2015, 06:12 AM
Hi, we are camping right now and will be traveling home on Wendsday the 2 of June. I will then be able to post pictures of what I did, but my wife also said to go to RV Net and do a search. Type in RV skylight covers and serval options will appear, she saw the same thing we did on that site.
Hope this helps?
Jim W.
06-02-2015, 06:31 AM
I did the same thing. Works very well. I have two skylights and with the sun coming through the ac just couldn't keep up. This solved the problem.
06-02-2015, 02:36 PM
shower sky;ight
I used a paper accordion shade from Home Depot and a pice of plastic. It was sunny when I took the pix.
06-03-2015, 07:07 PM
I see if this will attach to this thread.
Jim W.
06-06-2015, 05:21 PM
I applied a film to the underside of the skylight. Bought the film (it reduces u.v. penetration) from one of the big box stores. This still allows light, but seems to have reduced the "heat".
2010 Flagstaff 8528RKWS
2009 GMC 2500
06-06-2015, 06:10 PM
geezer with gadgets
We are also interested in doing something similar (just not sure what right now.) Was wondering about the outer skylight distorting or cracking from the reflected heat. Anyone notice a problem with doing this sort of mod?
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
06-06-2015, 06:54 PM
Cyber Phrenologist
My exterior bubble cracked and leaked due to sloppy installation at the factory. When I changed it I went back with a smoked tint bubble. Read about it here.
http://www.forestriverforums.com/for...nge-81711.html
But before that I was roasting in the summer heat and wanted to sleep a bit after sun up, so I took down the inner "garnish" and just put a piece of parchment paper over the little window in the garnish.
Cheap fix, about 10 minutes, helped a lot. And it didn't mess with the outer bubble.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
