Old 10-07-2019, 10:19 AM   #1
Silicone application
Yesterday I was inspecting the Furrion mount on my 2019 Micro Lite and the silicone was tacky with black residue, apparently from the rubber gasket. What should I use to safely remove/clean off the tackiness, and what silicone should I use to add a protective clear layer? Thanks.
Famoussenior is offline   Reply With Quote
Old 10-08-2019, 03:11 PM   #2
007matman's Avatar
It is likely not Silicone.
Typically, Silicone is not used on RV's and it makes a mess of things if it is used.
Can you send a photo of what you're looking at?
007matman is offline   Reply With Quote
Old 10-08-2019, 04:38 PM   #3
Correct, DO NOT use silicone on a R/V.
Most things mounted on the outside have butyl tape under the mounting flange (the tacky stuff) and the edges are often sealed with sealer.
Lexel, Geocel ProFlex and other products {Dicor/Alpha) should be used depending on area of application.
Days Camped: '16=46 '17=30 '18=51 '19=50
cat
