Old 08-26-2013, 11:03 AM   #1
Slide bracing???
WE will be living in our 5th 8528 for 6 months this winter. For those of you that live in one place for a lenth of time is there a need to brace the slide so they don't end up sagging? Are there any concerns when doing this and how is the best way? Would a cut to length 2x4 on edge be enough?
cdnwillyg is offline   Reply With Quote
Old 08-26-2013, 11:17 AM   #2
Fulltime family RVer
I'm not your target audience as I don't live in my camper for extended periods of time. But- most/all manufacturers indicate that you should NOT do this as it can cause damage if the camper moves as people walk around, but the slide doesn't as it is braced.
Old 08-26-2013, 11:27 AM   #3
Triguy's Avatar
x2
Not recommended. There is the very real risk of damaging your slideout if a stabilizer jack slackened or a tire lost air on that side; causing the slideout to essentially be pushed up.
These were more common when slides first began to appear but the current electric and hydraulic slides can take the weight.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
slide
