Old 07-11-2007, 09:12 AM   #1
Slide outs
Just wondering if anyone has had trouble with bolts shearing off on their slide outs. We have had our 829BHSS for two months now. Just 5 trips and the bolts sheared off on the slideout. Luckily it was at the house and I had all the tools to repair myself. The next time we went out, took the slide out and notice the bolts sheared again. This time the bolts did not come completely out and I was able to get back in easily. The trailer is at the dealer now getting repaired. Was just wondering if anyone else has had this problem? I am wondering if this is a problem this early what other problems will crop up? I hope I did not make a mistake with purchasing this brand.
Mickey & Teri
2006 Nissan Titan
2007 Flagstaff 829BHSS
twmw1126 is offline   Reply With Quote
Old 07-11-2007, 09:28 AM   #2
Grand Surveyor's Avatar
Not sure if this is the same problem but I had the bolts pull out of the housing. I found the bolts were too short with only a scant amount of thread holding the halves together. I posted the ordeal here earlier if you want to search. Brand has nothing to do with it. The supplier of the part is the culprit.
Me, one great wife who navigates & researches places to go & food to eat, one little boy who can't get enough camping, one border collie who refuses to be left behind!
2004 Fx4 F250 King Ranch SVT CC, PSD, Prodigy, no mods.
2003 GS272.
Grand Surveyor is offline   Reply With Quote
Old 07-11-2007, 09:29 AM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
I've not had that problem but, since you say the bolts sheared off, I wonder if they used the wrong grade of bolts in your trailer?
dimurrrw is offline   Reply With Quote
Old 07-16-2007, 07:02 PM   #4
welshman599's Avatar
Send a message via MSN to welshman599
Bolts shearing off??!!?? jeez that sounds major.... If FR or the dealer can't help, get a hold of Lippert Systems (they manufacture most of the slideouts for FR. and I find their service people very helpful. I got the service manual for mine through them and it's great.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 07-17-2007, 10:20 PM   #5
froglegs's Avatar
I notice that you are here in Kentucky! I had the same experience about two months ago when we were in PA. I replaced both bolts and when returned to KY had the dealer replace them with hardened bolts. I carry extrys just in case. What dealer replaced them?
2000 F-150 4x4 sc,off road pkg,Tow Pkg,5.4,3.73TL,2007 Flagstaff 8524RLS,and One Happy Maltese! See You Down The Road!!!
froglegs is offline   Reply With Quote
Old 07-18-2007, 08:03 AM   #6
I bought the trailer in Shepherdsville. Sunrise RV. Dealer is fixing the problem as we speak. Picking up later today or tomorrow. I will be carrying extras too.
Mickey & Teri
2006 Nissan Titan
Old 07-18-2007, 09:39 AM   #7
AKA Bluebird
dimurrrw's Avatar
You might want to check http://www.lci1.com (Lippert Components, Inc) under service/warranty / contact.
Old 07-18-2007, 01:18 PM   #8
froglegs's Avatar
That is the same dealer that we purchased from!! Was there this morning to get our slide cover replaced and a day-nite shade replaced. They had a 2008 1/2 flagstaff to come in this morning. Not too many changes. Great dealer to do business with!!
Old 08-01-2007, 02:41 PM   #9
I have a flagstaff 8524 RLS. I've had the bolt shear also. I replaced it with same hardness bolt as it came with and lubed the gear cogs and rails of the slide out. Have operated it 8 times since with no problems. I did find that the square tubing that fit over the round shaft left some room for play on bolt, when I installed new bolt I tightened it up so square tube met shaft, seems to work so far.
Darrell Downing is offline   Reply With Quote
Old 08-01-2007, 04:40 PM   #10
RAC
I am definitely going to look at mine
RAC is offline   Reply With Quote
Old 08-07-2007, 05:32 PM   #11
be carefull puting harden bolts in something has to give bolts are cheap the square tube is going to cost more.
2013 flagstaff 831flss diamond package 2014 gmc sierra 3500hd cc 4x4 sb 6.0 4.10 gears, 2000 gmc 4+4 2500hd 6.0 4.10 gears equl-i-zer jorden 2020
farmermark is offline   Reply With Quote
Old 08-19-2007, 09:26 PM   #12
Medic44's Avatar
I too have found this problem with my 8528RKSS Flagstaff 2006 unit. We were setting up a couple of weeks ago and just happened to look down and between the wheels and on the shaft off the motor which drives the slide out, what did I hind? It wasn’t a Jolly old man and 8 tiny reindeer. But a broken bolt half of it was still hanging there. I found a replacement bolt and fixed it. Then when we got home this week it was broken again so I replaced it with a stronger bolt. And like Darrell our tube had play in it. Then we tried it several times to make sure it would hold and so far its still hanging in there. Glad to see we weren’t the only ones having this problem.
Medic44 is offline   Reply With Quote
Old 09-08-2007, 09:10 PM   #13
2006 Rockwood 8298SS
Wink Adjusting the Slide
I have an 8298SS with the super slide. The cabinets touch at the top before the bottom does and it appears that the tilt on my slide needs to be adjusted. Has anyone done that, or do they know how?
Stiff12 is offline   Reply With Quote
Old 10-08-2007, 05:44 PM   #14
froglegs's Avatar
I think the secret is to really snug the bolt tight to the shaft. The square shaft needs a lot of torque. I have not had any problems since this was done.
Old 10-09-2007, 12:24 AM   #15
i had mine shear off i replaced them with a grade 8 bolt no problem (this was recommended by the dealer) i replaced all four bolts and nuts
chevy02 is offline   Reply With Quote
Old 11-04-2007, 11:24 AM   #16
I have a 2008 Flagstaff 831bhss and have had the same thing happen. The dealer (in Arkansas) said to replace them with grade 8 bolts. Said they should be grade 8 from factory. I replaced them and still had breakage. Talked to dealer in Shreveport, LA and they said the bolts were the wrong . The shoulder of the bolt should extend completely through the 1" tube , no threads inside the tube. I have purchased new bolts but am waiting until the current bolts break to replace with longer shouldered bolt.
Hope this fixes the problem. Maybe it will help you to. Remember to get grade 8 bolts.
Mickey
Mickey is offline   Reply With Quote
Old 11-05-2007, 07:08 AM   #17
milzat's Avatar
Mickey,
Have a look at what midnightpumpkin(John) came up with, on the slide-out drive shafts. Click here
milzat is offline   Reply With Quote
Old 11-14-2007, 11:34 PM   #18
O.K. After checking with lippert (who makes the slide out ) found you are NOT to lube rails and gear cogs (voids warranty)........Great to not have that info on purchasing unit. Found they stated to have "shoulder bolt" 1 1/2" long. Well I measured and you need unthreaded portion to reach through shaft/square tube area. I used a 1 3/4" which clears rotation of unit and puts all pressure on area not cut with threads. So far so good. Also check there website as they say to manually operate unit you must disconnect power or electrical feed back may damage motor, (voiding warranty) another thing you aren't made aware of when purchasing unit. Good luck.
flagstaff
