Old 04-18-2009, 05:31 PM   #1
slide will not close
We have a 2006 28ft flagstaff fifth and opened the slide and now it will not close. It sticks on the top and the bottom tries to close but it`s like it pushes up.
krosger is offline   Reply With Quote
Old 04-22-2009, 12:51 PM   #2
My 2004 Flagstaff 5th wheel had the same problem. We had to gently push to get the slide to go out or in. I purchased a can of slide out lubricant at Wal-Mart and sprayed the teeth and gears under the slide. We worked the slide a few times and it seems to be OK.
Are the seals sticking? If so they need lubricatede as well. I use a silicone lubricant on these to keep them from sticking.
2006 2500HD Chevy 6.0 Gas Ext Cab Short Bed
2004 Flagstaff 8528BHSS 5th Wheel
Dear Wife, two daughters and four dogs
dpgllg is offline   Reply With Quote
flagstaff
