Old 08-19-2012, 01:51 PM   #1
dilgerc's Avatar
Slideout lube v-lite 30wfkss
I am thinking it may be getting time to lube the slideout.. Does anyone know if I need to remove the bottom cover that encloses the bottom of the trailer or do I just extend the slideout and spray anything that might look like it would need it. Thanks for the help.
dilgerc is offline   Reply With Quote
Old 09-04-2012, 12:40 PM   #2
Should just need to extend the slide and lube exposed areas. Wipe off the old stuff on there the best you can. Don't forget to use a "dry lube". There are several out there that work well.
Wumba is offline   Reply With Quote
