Old 04-26-2012, 06:15 PM   #11
Fire Instructor's Avatar
Then it sounds like it's either the motor, a connection (power or ground connection), or an in-line fuse near the motor. You really need to find the motor to diagnose further.
I don't know your floorplan, but my slide's motor is inside (away from weather), under the fold-out couch. Is there ant fixed furnature or cabinets near your slide that it could be tucked under?
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 04-26-2012, 06:16 PM   #12
TURBS's Avatar
there should be a breaker for the slides as well .
Old 04-26-2012, 06:52 PM   #13
striper1's Avatar
Thanks guys for your help,i will call the dealer tomorrow, the DW found the manual crank after all my cussing,the slides out and its time to move on,concentrait on the dutch oven gathering saturday.
Mike & Penny
2002 Ford F250 7.3 Powerstroke Diesel
2012 Flagstaff Classic Super Lite.
Nights camped 2012 (30)
striper1 is offline   Reply With Quote
Old 04-26-2012, 07:29 PM   #14
j2detroit's Avatar
Check under your camper just behind the battery's and propaine tanks that is were the breakers are located on my 06 Cherokee slides wouldn't go in on time got under it and they had popped out reset them and bang have not had any problems with again this was 4 years ago good luck
j2detroit is offline   Reply With Quote
Old 04-26-2012, 07:39 PM   #15
Flatbroke
Everything I find say motor is under the slide
Flatbroke is offline   Reply With Quote
Old 04-26-2012, 08:01 PM   #16
Herk7769's Avatar
If your slides have motors and not hydraulics, look for a pigtail type 30 amp breaker for each main slide within 18 inches of the battery. My pigtails are green.
The wardrobe slide (opens with steel wires and not a rack and gears) has a fuse in the fuse panel in my camper.
I relocated mine and put autoresetting fuses in place of the single blow 30 amp ones when I re-did the battery compartment.
Hope this is helpful
ID:	12838   Click image for larger version
Name:	9 Nov 2009 003.jpg
HAM CALLSIGN - KC3FFW
Old 04-27-2012, 05:26 PM   #17
So, Striper, what did the problem wind-up being?
Fire Instructor
Old 04-27-2012, 10:05 PM   #18
striper1's Avatar
@fire instructor dont know finally found the manual crank to get it out,gonna take it to dealer monday,hope it aint nothing major,i think what upsets me most is its only the 2nd trip and I think about my wilderness I had for 12 years and it NEVER seen the inside of a shop,just the new trailer did I do the right thing jitters.
Mike & Penny
Old 05-05-2012, 07:44 PM   #19
striper1's Avatar
Turns out the slideout motor needs to be replaced,hope the new one lasts more than 54 days.
Mike & Penny
