07-25-2016, 06:53 PM
#21
Yes bobneal69. It is the CO / LP detector that is under the island sink. Made a mistake calling it smoke detector. Where is fuse located?
07-25-2016, 06:56 PM
#22
Mddle of the Rd Extremist
Originally Posted by Brother Les
install an after market smoke detector. we removed our first one, as it was junk.
X2....went thru the same process of checking everything that could cause it three days in a row. Said "screw it" and replaced the detector and haven't had any more problems
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
07-25-2016, 10:57 PM
#23
I'll post a picture tomorrow night. On mine it is the first fuse in line, 5 amp. I keep a pair of needle nose plyers in the closet just for that purpose.
07-25-2016, 11:15 PM
#24
In their infinite wisdom, FR put our smoke alarm in the kitchen and just to the side of the stove top. Can't cook anything without setting it off. I'd move it, but it is mounted with screws and would leave exposed holes. I just remove the battery when we set up and don't put it back in till we strike camp. I did add a second unit in the bedroom.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
07-26-2016, 04:57 AM
#25
If it's not in use while you're in the camper, why put the battery back in at all?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
07-26-2016, 05:24 AM
#26
They put it there because the most likely place for a fire to start in an RV is due to something going wrong with the stove.
Get yourself a quart zip lock baggy and a heavy duty 3" rubber band, the kind the post office uses to band your mail together when you have a lot. Then when you are frying that bacon, or any other item that can cause smoke, use the baggy and the rubber band to cover the smoke detector. or you can pull the battery, BUT if you do, make sure you put the battery back in when finished cooking.
07-26-2016, 05:35 AM
#27
Hair spray will set off the CO/Propane alarm as will low battery. Many other spray materials such as lysol or air freshener will also set it off. It is recommended not to disconnect it as it is very easy to forget it is disconnected and I for one would not want to sleep in an RV without a CO/Propane detector. Having it go off accidentally is an inconvenience, having it not go off because it is disconnected could be fatal.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-26-2016, 12:37 PM
#28
Originally Posted by Wobbles
True, many a time at home, the DW uses it to let me know my toast is ready.
You must have the same model "toaster" that I have!
2013 Coachmen Mirada 35DL
Chuck and Susan, RIP Toby and Gracie, the greatest dogs.
07-26-2016, 11:56 PM
#29
The fuse is the top left one. In this picture it is a 5 amp but orginally it was a 3 amp.
07-26-2016, 11:58 PM
#30
MeepMeep or Brother Les where did you get your replacement and what brand and model did you use?
07-28-2016, 03:57 PM
#31
Where did you get your replacement and what brand and model did you use? The only reason I haven't replaced mine is I have read that the replacements are as troublesome as the old one. Mine is only 2 1/2 years old from date of manufacture.
07-29-2016, 11:05 AM
#32
That was about the same age as my detector when it died. Went to Camping World and picked up one of these (think it was around $70):
MCPO (Retired)
07-29-2016, 12:42 PM
#33
Thank you. :-)
