Old 07-25-2016, 10:56 AM   #1
OswegoLion's Avatar
Smoke Alarm going off for no reason.
In the last 4 months alarm went off 4 times. Twice propane was off. It is a 2016 8528 IKWS. It is loud don't know remedy. Help with suggestions!!
Thanks.
OswegoLion is offline   Reply With Quote
Old 07-25-2016, 11:01 AM   #2
AquaMan's Avatar
Mine went off while in Nashville the past week every time I opened the door. The heat was so bad that it set the alarm off!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-25-2016, 11:09 AM   #3
OswegoLion's Avatar
Crazy question here. But could hairspray set it off?
Old 07-25-2016, 11:10 AM   #4
TURBS's Avatar
Yes!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-25-2016, 11:17 AM   #5
Brother Les's Avatar
Thanks.
install an after market smoke detector. we removed our first one, as it was junk.
Brother Les
Old 07-25-2016, 12:44 PM   #6
The smoke alarm will go off if the house battery is low and/or the alarm itself is going bad. (and hair spray)
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
USMC Okie is offline   Reply With Quote
Old 07-25-2016, 12:47 PM   #7
RudysWorld's Avatar
Mine would go off when house batteries would over charge due to bad battery.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 07-25-2016, 12:47 PM   #8
AquaMan's Avatar
The smoke detectors are not usually wired into house battery, (at least not in my last 3 campers). The CO/gas detector is.
Old 07-25-2016, 12:47 PM   #9
Also some have an expiration date on them. Even though you have a 2016 unit doesn't mean it has a new detector. We bought a 2011 unit in 2010 and FR had put a LP detector that expired in 2009 in it.
CapitolPCO is offline   Reply With Quote
Old 07-25-2016, 12:48 PM   #10
Hair spray will set off the Gas alarm
Dc8mdtmech is offline   Reply With Quote
Old 07-25-2016, 12:59 PM   #11
Wobbles's Avatar
Thanks.
I have had mine go off from campfire smoke when just the screen door was open. Smoke was carried by the wind from 30ft away and really could not be seen very well. Keep the big door closed now as there was a stink from smoke on the TT.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 07-25-2016, 01:01 PM   #12
Pull the unit out of the trailer and blow it off gently with some compressed air or vacuum it with a shop vac. Bugs, spiders for sure and dust particles can and will cause them to go off.
A small coating of debris will activate it when the temp starts to rise as the condensation will trigger things.
MtBiker is offline   Reply With Quote
Old 07-25-2016, 01:14 PM   #13
Occasional campers
It's not unusual for these detectors to go bad; they reach "end of life". I had to replace ours and the new one has been fine. In a few years I could have to do it again.
Ray and Ann is offline   Reply With Quote
Old 07-25-2016, 01:24 PM   #14
bpa098's Avatar
if windows are open or the screen door and my GF is cooking most times ours goes off too lol
bpa098 is offline   Reply With Quote
Old 07-25-2016, 01:28 PM   #15
Wobbles's Avatar
True, many a time at home, the DW uses it to let me know my toast is ready.
Bob & Michelle
Old 07-25-2016, 01:44 PM   #16
X2.
You can also buy a battery powered detector & if only the hard wired in dectector goes off, you'll know that it's bad.
mtnlvr is offline   Reply With Quote
Old 07-25-2016, 03:00 PM   #17
Smoke Alarms
Thanks.
I have experienced, on some of the cheaper models, that very high humidity will set them off. Suggest replacing unit with the best that you can afford.
kcdelan is offline   Reply With Quote
Old 07-25-2016, 03:40 PM   #18
rracer5's Avatar
X2
If it's cool inside and you open the door in the AM and it's really humid outside, that's what causes condensation at the ceiling level affecting the smoke alarm.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-25-2016, 06:08 PM   #19
Defective alarm
Forest River puts in the cheapest alarm they can buy $10 at Home Depot . Buy a better quality one and your problem will be fixed as I did.
bobquest is offline   Reply With Quote
Old 07-25-2016, 06:17 PM   #20
Are you asking about the smoke detector or propane detector. I have no input on the smoke detector but lots on the propane detector. Many things set mine off: opening the refrigerator door, lighting the oven, spraying febreeze, sometimes it just goes off on it's own. It is no where near expired but it is a piece of junk. When it goes off I pull the fuse and put it back in. The propane detector resets itself and is good for another week or so. I'd replace it if I thought the replacement would be any better.
bobneal69 is offline   Reply With Quote
