Old 04-21-2014, 07:53 AM   #1
Socket size for wheel lug nuts
I need to know the lug size for the aluminum wheels on our trailer (832IKBS). I think they are 1/2 inch studs.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 04-21-2014, 07:57 AM   #2
13/16" thin wall 6 point socket for alum. wheels.
Some old sparkplug sockets fit the bill just fine.
Old 04-21-2014, 08:00 AM   #3
Thanks! Should have asked earlier. Would have saved me a lot of grief getting the right size!
Old 04-23-2014, 02:07 PM   #4
Our wheel lugs turned out to be 3/4". All is well though!
Old 04-23-2014, 02:24 PM   #5
BamaBob's Avatar
You DO have a Torque Wrench for that 3/4" Wheel Lug Socket, right?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 04-23-2014, 02:29 PM   #6
Yes. Had the factory tires taken off and Load Class "D" installed. Just making sure I am able to check that the nuts are tight after the first trip.
Old 04-23-2014, 02:46 PM   #7
BamaBob's Avatar
Nice, what brand did you buy? (I am trying to decide myself)
Old 04-23-2014, 02:56 PM   #8
Carlisle Radial Trail
They used to have bad reviews, but not any more. Reviews are great now with a new and improved tire. Very impressive tire on the rim!
Old 04-23-2014, 09:20 PM   #9
VinceU's Avatar
Most SAE bolts and nuts you'll encounter go by the same rule of thumb
Bolt heads are measured to 1.5x the diameter of the bolt ie: 1/2" bolt equals 3/4" head.
Most full size nuts are the same as the bolt head +1/16"- 1/2" bolt equals 3/4+ 1/16" = 13/16".
There are more compact nuts, often called Navy nuts which measure the same as the bolt head, no 1/16" adder. They are not as common as the SAE sizes. Knowing this saves extra trips to the toolbox.
Old 04-23-2014, 09:25 PM   #10
Also true and wheel studs are definitely SAE and also do not have hex heads but button flat heads with a knurled shank and are IIRC a type 10 bolt and use type 8 nuts which is why they will normally have stripped threads rather than messing up the stud.
wheel
