Old 05-19-2019, 02:36 PM   #1
kdot's Avatar
Solar power questions
I am a new E-Pro 19FBS owner and have never had solar power built in before. This may be a dumb question, but I'm accustomed to keeping myRV plugged in to 110 when it's waiting for the next trip to combat the parasitic drain. Do I still have to do this with the factory solar on the roof?
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 05-19-2019, 02:57 PM   #2
Flybob's Avatar
Maybe a dumb question, but are you sure you have solar panels and controller on your setup or is it just solar ready. Solar ready is a marketing gimmick that is simply a connector and some wire to the battery. I did not see solar as a standard. feature or an option. Did you add solar?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-19-2019, 03:00 PM   #3
kdot's Avatar
Kdot
I do have the solar panel on the roof. It was standard on my new FBS.
2017 RPod179
2016 Honda Pilot
Old 05-19-2019, 03:04 PM   #4
Flybob's Avatar
Ok I did not see that in any of the literature. If you have a panel and a controller, it will keep the battery charged during storage assuming the battery cutoff switch is on and the panel is not covered.
TST Tire Monitors
2 100W solar panels
Old 05-19-2019, 03:08 PM   #5
kdot's Avatar
Kdot
Flybob, thanks for the info!
2017 RPod179
2016 Honda Pilot
Old 05-19-2019, 03:51 PM   #6
OP may have to experiment with the battery disconnect. In my Geo Pro, with the battery disconnect OFF, my factory installed roof solar panel still charges the batteries.
The panel still chargers in cloudy weather as well. Have seen 2.5 - 3.0 amps during overcast skies.
2019 Flagstaff E-Pro 14FK
JS Stanley is offline   Reply With Quote
Old 05-19-2019, 11:48 PM   #7
I would think most of the time, a solar controller should be connected straight to the batteries. Reason for this is that many solar controllers will be damaged if the battery load is removed from them with the PV array still connected to the input of the controller.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
