Old 02-29-2016, 05:07 PM   #11
TURBS's Avatar
Stabilizer Jack Problem
Originally Posted by OldCoot View Post
BS, they are not strong enough to even stabilize a trailer if used correctly. Better to reinforce them to start with. They're only made of 0.072 thick material measured over 2 layers of paint. You can block a leg up between 2 pcs of 2 x 4 and bend them by just jumping in the middle of them. I only wt 150# and have bent them this way!!!
Funny, I've not had a problem in 10 years........
You must be doing it wrong.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-29-2016, 05:15 PM   #12
Left Coast
And let the battle begin!......
Old 02-29-2016, 05:21 PM   #13
I don't recommend jumping up and down on ANY of our floors! Haha
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-29-2016, 05:22 PM   #14
No problems here, reinforcing them was one of the first things I did before even using them when it was new. I don't have to worry about them now. I can probably use the rear, axle and front and lift the entire trailer, but I won't due to the flimsy frame.
Old 02-29-2016, 05:24 PM   #15
Not the floor, a jack leg.
Old 02-29-2016, 06:49 PM   #16
SeaDog's Avatar
hundreds of folks have used stabilizers without problems when used in accordance with the manual. I'm sure your reinforced stabilizers work much better, however that is not what comes on the Rigs. If you are sure of your figures why not bring a suit and make yourself some money and help out your fellow campers given the inadequate proprieties of the stock stabilizers.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-29-2016, 07:07 PM   #17
I run mine down until the motor just about stalls which is probably more than most folks do, but our trailer does not move when we walk around in it. Not interested in filing a frivolous lawsuit when I haven't been harmed or inconvenienced. I reinforced mine so I don't have to worry about bending them. I've posted pictures and dimensions on how to reinforce them so other folks can do it if they want. I've reinforced 5 sets, 2 sets for me and 3 for others.
Old 02-29-2016, 07:11 PM   #18
TURBS's Avatar
Unnecessary waste of time and money, as stated before if used properly they are plenty strong enough.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-29-2016, 07:27 PM   #19
Can say the same about moding diesel trucks. BTW, had the material and it cost me nothing. To each his own.
Old 02-29-2016, 07:33 PM   #20
TURBS's Avatar
Not true, I actually gained reliability, horsepower and fuel mileage!
Engine runs cooler and I
Lowered my egt's
You gained what? "weight"?
2015 Columbus 320RS
2008 2500HD Duramax
