Old 02-28-2016, 10:44 AM   #1
Stabilizer Jack Problem
Just got a 2016 Micro Lite 21FBRS, took it to Florida for a week and upon returning home, parked it in my driveway. While leveling the RV using the stabilizer jacks, one of the jack supports bent and the jack is no longer level. Has anyone else had a problem with the stabilizer jacks on this or any other Flagstaff model? Thanks in advance for any replies.
2016 Flagstaff Micro Lite 21 FBRS
2016 Nissan Frontier SV 4X4
tort1305 is offline   Reply With Quote
Old 02-28-2016, 10:57 AM   #2
SeaDog's Avatar
The stabilizers jacks are for stabilizing only not for leveling your rig. You level side to side by driving up on blocks of some kind and level front to back using the lounge jack.
You should be able to straighten the support with a little elbow grease and some choice words.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-28-2016, 11:13 AM   #3
They are flimsy at best and need reinforcing. I have reinforced 4 sets by splitting a 29' long pc of 2-1/4" x 0.120 wall square tubing and welding it to the bottom of each leg. The 5th and last set I did (OCW's) I used 1-1/2 x .120 angle and made channels to fit.
Name:	Stab Leg reinforcments.JPG
ID:	100625   Click image for larger version
Name:	Stab Leg reinforcments ready to trim.JPG
ID:	100626   Click image for larger version
ID:	100627   Click image for larger version
Old 02-29-2016, 02:47 PM   #4
Herk7769's Avatar
Been there; done that ....
Got the T Shirt ...
Name:	camper damage 038.jpg
HAM CALLSIGN - KC3FFW
Old 02-29-2016, 02:58 PM   #5
This.
Iwritecode is online now   Reply With Quote
Old 02-29-2016, 05:25 PM   #6
oops
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 02-29-2016, 05:28 PM   #7
TURBS's Avatar
If used properly they should never bend.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-29-2016, 05:47 PM   #8
BS, they are not strong enough to even stabilize a trailer if used correctly. Better to reinforce them to start with. They're only made of 0.072 thick material measured over 2 layers of paint. You can block a leg up between 2 pcs of 2 x 4 and bend them by just jumping in the middle of them. I only wt 150# and have bent them this way!!!
Old 02-29-2016, 05:53 PM   #9
Georgia Rally Coordinator
aceinspp's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
I tend to agree as I've had two tt now with them and never had an issue IF YOU READ THE INSTRUCTIONS. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 57
aceinspp is online now   Reply With Quote
Old 02-29-2016, 05:53 PM   #10
Herk7769's Avatar
Mine failed when I needed to raise the front landing gear and forgot to raise the stabilizers. (Newbie mistake - quick fix; just took money).
Old 02-29-2016, 06:07 PM   #11
TURBS's Avatar
Funny, I've not had a problem in 10 years........
You must be doing it wrong.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-29-2016, 06:15 PM   #12
Left Coast
And let the battle begin!......
Old 02-29-2016, 06:21 PM   #13
I don't recommend jumping up and down on ANY of our floors! Haha
Old 02-29-2016, 06:22 PM   #14
No problems here, reinforcing them was one of the first things I did before even using them when it was new. I don't have to worry about them now. I can probably use the rear, axle and front and lift the entire trailer, but I won't due to the flimsy frame.
Old 02-29-2016, 06:24 PM   #15
Not the floor, a jack leg.
Old 02-29-2016, 07:49 PM   #16
SeaDog's Avatar
hundreds of folks have used stabilizers without problems when used in accordance with the manual. I'm sure your reinforced stabilizers work much better, however that is not what comes on the Rigs. If you are sure of your figures why not bring a suit and make yourself some money and help out your fellow campers given the inadequate proprieties of the stock stabilizers.
Retired Navy
Old 02-29-2016, 08:07 PM   #17
I run mine down until the motor just about stalls which is probably more than most folks do, but our trailer does not move when we walk around in it. Not interested in filing a frivolous lawsuit when I haven't been harmed or inconvenienced. I reinforced mine so I don't have to worry about bending them. I've posted pictures and dimensions on how to reinforce them so other folks can do it if they want. I've reinforced 5 sets, 2 sets for me and 3 for others.
Old 02-29-2016, 08:11 PM   #18
TURBS's Avatar
Unnecessary waste of time and money, as stated before if used properly they are plenty strong enough.
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-29-2016, 08:27 PM   #19
Can say the same about moding diesel trucks. BTW, had the material and it cost me nothing. To each his own.
Old 02-29-2016, 08:33 PM   #20
TURBS's Avatar
Not true, I actually gained reliability, horsepower and fuel mileage!
Engine runs cooler and I
Lowered my egt's
You gained what? "weight"?
2015 Columbus 320RS
2008 2500HD Duramax
