Old 06-07-2016, 07:50 AM   #1
OswegoLion's Avatar
Stabilizer jacks under LR slide for 8528 IKWS
Hi. a quick question. Besides leveling are the stabilizer jacks s good idea for the longer slide out?
It seems to rock when ever we walk. It seems like leveling doesn't eliminate it. Thanks.
OswegoLion is offline   Reply With Quote
Old 06-07-2016, 07:55 AM   #2
jeff64's Avatar
lots of threads on this subject. Do a search, you'll get a good feel for what methods have given acceptable results . Generally, don't support on the slide out itself. Frame of TT only for anything additional. Don't go crazy trying to overcorrect with stabilizer jacks to level TT, that is what boards or blocks under the wheels are for
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-07-2016, 08:03 AM   #3
This Rockwood has (14) supports under it and they were Still Complaining about Movement! Youroo!!
ID:	110372   Click image for larger version
Old 06-07-2016, 08:19 AM   #4
Don't do it.
Get some JT Strong Arms or the equivalent along with X-Chocks and center scissor jacks under the frame/axle mounts.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 06-07-2016, 11:43 AM   #5
Stormrider151's Avatar
We had that problem . Simple fix. Just put some blocks under the bottom step. Takes all the entry and exit motion out.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-07-2016, 11:48 AM   #6
OldGuysRule
Renegade837's Avatar
We are seasonal down by the beach, but I pull it home for the winter to camp late season and early spring. I had the best results with using X-chocks. It eliminated most, if not all, the forward/backward motion. I then use a plain old set of aluminium pyramid jacks on the frame. I put one pair of pyramid jacks just rearward of the rearmost wheel, one pair just in front of the front most wheels, and one pair between that set and the forward stabilizers. I then put a pair under the middle step for the fold-out stairs. This gets rid of most of the movement.
Renegade837 is offline   Reply With Quote
8528, jacks, slide
