Old 11-15-2010, 08:33 AM   #11
Villa Estate 392FLFB
The_Stuff's Avatar
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-15-2010, 08:47 AM   #12
The Old Man
Willis's Avatar
Originally Posted by Coupey View Post
Thanks for the swift reply, would that be used for the Sirus radio which came fitted with the 5er, clearly doesn't work over here in the UK though
Well, it's my understanding that in the UK that item is used by MI6 to track suspicious activity among "so-called" recreational campers.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 11-15-2010, 08:54 AM   #13
Infractee
It is exactly the same coax connector, identical. The plastic around it may be slightly different to fit their own receiver tho. I am using my sirius sportster receiver modded into the XM adapter plate that came in my new Rockwood, I depinned the coax from the plastic connector and it plugs directly into the back of the sirius radio and if you look at the antenna aiming strength bar it is 100% strength.
I looked at that meta answer link you found, I think it is a lot of maybes and freq talk. All I know is it works perfectly for me!
RhoZeta is offline   Reply With Quote
flagstaff
