11-15-2010, 04:41 AM
Strange Object on my Roof - ???
Whilst cleaning my 5er at the weekend I decided to have a look on the roof and came across this little black box with a wire coming from it next to the rear toilet vent pipe. Does any body have any thoughts as to what it is and used for..thank you
11-15-2010, 05:20 AM
That's a satellite radio or GPS antenna.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
11-15-2010, 05:27 AM
Thanks for the swift reply, would that be used for the Sirus radio which came fitted with the 5er, clearly doesn't work over here in the UK though
11-15-2010, 07:34 AM
Well in my 5th wheel it is the XM satellite radio antenna. It is a standard mag mount car antenna that goes to the Concertone SkyFi removable XM receiver.
Since its a magnetic mount, it needs a metal plate that is screwed to the roof. All the goop is to cover the mounting screws.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
11-15-2010, 07:51 AM
Infractee
That is a satellite antenna, they are generic and can be used for either XM or Sirius receivers.
I had thought I had read a few years back on a sirius forum that people in the UK could recieve a signal as well?
11-15-2010, 08:53 AM
Coupey are you for real????
I believe it says XM on it and it is for the satelite radio............
Puff puff pass..........
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
11-15-2010, 08:56 AM
thanks for all your replies, since I am new to the 5er and sat radio I thought it best to ask, which I did and got the answer, thanks
as for trying the sat radio in the uk I will unbox it and try it on our next outing
11-15-2010, 09:00 AM
Really? I had no idea. When I switched from Sirius to XM in the car, I ran a new antenna lead. It looked like the connector was different, but to be truthful, I never tried to check.
11-15-2010, 09:03 AM
One Question - 3 different answers
11-15-2010, 09:26 AM
11-15-2010, 09:33 AM
Villa Estate 392FLFB
One state/province at a time!
11-15-2010, 09:47 AM
The Old Man
Well, it's my understanding that in the UK that item is used by MI6 to track suspicious activity among "so-called" recreational campers.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
11-15-2010, 09:54 AM
Infractee
It is exactly the same coax connector, identical. The plastic around it may be slightly different to fit their own receiver tho. I am using my sirius sportster receiver modded into the XM adapter plate that came in my new Rockwood, I depinned the coax from the plastic connector and it plugs directly into the back of the sirius radio and if you look at the antenna aiming strength bar it is 100% strength.
I looked at that meta answer link you found, I think it is a lot of maybes and freq talk. All I know is it works perfectly for me!
