Old 09-15-2011, 07:33 AM   #11
jimh's Avatar
i found out the hard way that there was a difference. bought the one with the drain only to get home and find out it was too small. my rule is to take the old part with me. i broke the rule with predictable results.
wish there was a way to have the water not drain next to heater. i put a piece of cardboard around the hole when i pull it out (like i do the filter on my washer).
jimh is offline   Reply With Quote
Old 09-15-2011, 08:04 AM   #12
Herk7769's Avatar
Camco Water Heater Drain Valve Wrench 11653 RVPartsNow.com
They have an inexpensive correctly sized socket for the anode too.
Thanks Chap, I looked all over for that. I knew I had seen it but could not find it. That bushing Charlie mentioned would also work with the Atwood anode.
HAM CALLSIGN - KC3FFW
Old 09-15-2011, 08:08 AM   #13
MtnGuy's Avatar
I had a bit of trouble finding that puppy, also. I remember that I had posted to the link in the past, so I had to do a search of my threads to find it.
Old 09-15-2011, 05:41 PM   #14
Bsnyder32's Avatar
Only problem I see with the valve wrench is it fits the petcock not a plug. That takes a 1- 1/4" socket.
Bsnyder32 is offline   Reply With Quote
Old 09-15-2011, 05:52 PM   #15
MtnGuy's Avatar
I think the size is 1 1/16th.
Old 09-15-2011, 06:04 PM   #16
Herk7769's Avatar
Whoops... My bad. I did not read closely enough. I am sure they make a similarly priced anode wrench too.
http://www.americanrvcompany.com/Cam...RV_p_6094.html
Here it is.
Old 09-15-2011, 09:31 PM   #17
Bsnyder32's Avatar
Thanks, that will work. That is a whole lot better than carrying a 3/4" ratchet.
Old 09-16-2011, 05:32 AM   #18
Herk7769's Avatar
Jim posted about using the anode to drain the tank.
I drain my tank using the low point drain. With the red low point drain open, I pop the pressure relief valve and drain the hot water tank when the rest of the system drains. That way when I take out the anode there is only a tiny bit of water left. Make sure you reseat the pressure valve and not leave it open all winter or it will not reseat properly.
Old 09-16-2011, 06:54 AM   #19
jimh's Avatar
didn't know that would work. guess i was thinking that it was made like a home wh w/both lines entering and leaving the top. looks like i'm going to have to change my mine set.
