30 amp service!
Hi, I have the 26 FKS and you are fine with the 30 amp service. It actually will do better than the 50 amp service in most situations. The 30 amp service makes 30 amps available for the different items in use in you trailer. A 50 amp service actually provides two 25 amp circuits. I had a motor home that I could not run my coffee pot and the microwave at the same time because they were on the same circuit. With the 30 amp circuit I do not have a problem. You will be able to run your air conditioner and make coffee at the same time. I was able to keep cool in AZ a month ago with the outside temperature at 95 degrees. The only issue I have with my 26 vfks is the unit needs to be elevated 2" on the side opposite the slides or the unit becomes un-level when bedroom slide goes out. The stabilizer jacks will not keep the unit from tipping when the bedroom slide is put out.
Dennis
_____________________________
2007 F-150 Super Cab
5.4 L V8, Tow Pkg, Equalizer Hitch
2015 Flagstaff VLite 26VFKS
