Old 05-13-2014, 10:11 PM   #11
Take The Road Less Travld
MuddauberE's Avatar
Yeah, then I don't think I have true surround sound. But it works better than the little speaker on the tv
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 05-13-2014, 10:20 PM   #12
Herk7769's Avatar
Amen to that!
HAM CALLSIGN - KC3FFW
Old 05-14-2014, 05:22 AM   #13
Witch Doctor's Avatar
Originally Posted by Herk7769 View Post
It is my understanding that TV output using the red/white RCA plugs will not be true surround sound. The Concertone has a "theater" setting the will output left/right stereo audio to the back speakers with a 0.5 second delay to "simulate" surround sound; but it is not.
ONLY the digital output TVs (with COAX or Toslink) can send the Dolby signals to the Concertone (or any other amplifier).
Thanks Lou, but now you are talking past my pay range.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-14-2014, 05:56 AM   #14
Herk7769's Avatar
They say a picture is worth something, so here is a link to what I am talking about.
Toslink Socket - Buy Toslink Socket,Digital To Analog Audio Converter,Analog To Digital Audio Converter Product on Alibaba.com
The "dog house" shaped "door" is an optical socket (Toslink) and takes a fiberoptic cable (photo of ends attached). There may be one on the back of your TV and there is one on the back (not front) of the Genesis and ZX-800 Concertone radios.
The TV may also have a yellow/orange single RCA jack. This is a COAX digital audio output. There is a marked Digital RCA socket (female) on the back (not front) of the Genesis and ZX-800 Concertone radios. This can be used with a single shielded RCA Male to male audio cable as long as it is well shielded (or buy a shieled one at Best Buy).
Old 05-14-2014, 06:40 AM   #15
Kaadk's Avatar
I think it depends on which Genesis he has. The GT-2.0 in ours has both a Toslink and a COAX but they are for output, not input. I can't send a digital signal into the GT-2.0. Instead I wired RCAs to carry the stereo sound back to the Genesis. I won't have true surround sound, but at least I have some sound when watching over the air or from an iDevice hooked up to the HDMI of the TV.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 05-14-2014, 06:59 AM   #16
B and B's Avatar
Kaadk- Depending on how well the Gensis decodes dolby they RCA may provide some rear channel decoding with RCA. I have both hooked up, with the Optical full surround is possible. With the AC on you can not hear the difference so I just us RCA connections for audio most of they time from the TV. My sat receiver feeds the TV as well so this gets to the Genesis via RCA feed.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-14-2014, 07:18 AM   #17
Kaadk's Avatar
Brian
Yeah, I believe there is 'some' decoding, but the speakers are so cheap I don't think it makes much of a difference. Are you using Toslink with a GT-2.0 or a 3.0? My Konka TV only has COAX audio out so that was all I could try hooking up. But much like I figured based on the manual only referring to output settings on the GT-2.0, it didn't work.
Old 05-14-2014, 08:23 AM   #18
Herk7769's Avatar
Can you upload a scan of the page that has the rear connections? I don't have a digital manual for a Genesis 1.0 or 2.0. (Uploading the manuals would be awesome!)
As far as I know, the digital connections are inputs. There would be no reason for there to be digital outputs since the speakers connect up to the unit. Not saying you are wrong (I have no facts to say that), just that it would not make any sense to me for them to be digital outs.
Old 05-14-2014, 08:36 AM   #19
Kaadk's Avatar
The original's sitting in the TT in storage, but I got my digital copy from here:
http://manuals.heartlandowners.org/m...11.26.2011.pdf
It's the same as the one in my TT.
It doesn't specifically label them as input/output but page 25 that shows the audio setup refers to an Audio Out setting. Combined with my trial and error on the COAX I can only assume they're for output only.
I figure the outputs are there to support sending to an external processor/amp if you didn't want to use the onboard speakers.
Old 05-14-2014, 08:42 AM   #20
I guess I'm still confused. Just went out to the trailer put on tv to video. turned on the Genesis 3.0 / TV is Toshiba. Used the CD Seabiscutt. You can hear the difference in each speaker as the horses run the sound comes out the rear speakers while the people talking comes from the center and front. You can hear the difference from the speakers isn't that surround sound. The dealer said and left the RCA cables attached and installed a HDMI cable. Maybe I don't know what surround sound is? It is set to 5.1 or I can switch it to Doby Sound or stereo or mono. I have 5 speakers in the ceiling and a sub-woofer in the entertainment center. Just in my Solon main area which is A. You can even hear the horses hoofs running as they will travel in a circle around the front and back with music coming out the center speaker.
