Old 07-30-2019, 02:23 PM   #1
dbackwoods's Avatar
Swaying in a 21DS! Help!
I have a 2017 Expedition with tow package and towing a microlite 21ds. We have a Fastway e2 anti sway hitch with weight distribution bars that were put on by the service department at the dealer. When driving the highway between 65-70mph and wind over 10mph Iím still feeling the trailer sway. We are taking a 30 hour trip across country to Yellowstone in a couple weeks and I want to feel comfortable driving! What are we doing wrong? We are not exceeding tongue weight.
dbackwoods is offline   Reply With Quote
Old 07-30-2019, 02:41 PM   #2
Chief T's Avatar
Here's a few observations without your specifics:
You will always have a bit of sway, especially when big rigs pass you buy.
I have a Fastway E2 Trunnion WDH and works great. You didn't mention if you have round bar or square bar.
Don't drive faster than 65.
LT or P-rated tires on your Expy? If P, add more pressure to tire. I usually fill mine to 44/45 psi. Tire is 51 psi max cold temp. Door jam sticker says to fill to 35 psi for normal driving.
Ensure TT tires are filled to max cold psi and monitor along journey.
Is your weight in TT evenly distributed. Irregardless of "not exceeding tongue weight", too much weight in the back of the trailer will cause sway.
Oh, one more thing. Expy's tend to have a soft rear suspension. Stronger shocks may help some.
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 17
Chief T is online now   Reply With Quote
Old 07-30-2019, 02:41 PM   #3
Would be helpful to have a pic of your vehicle and trailer hitched up in a level lot.
Could be hitch not adjusted appropriately, load not distributed correctly, problem with your vehicle suspension, or other things.
Do you have a tongue weight measurement? How do you know you aren't exceeding tongue weight?
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 07-30-2019, 03:36 PM   #4
dbackwoods's Avatar
It’s a square bar e2. I’m getting pulled around even when I’m not around any other vehicles. We’ve been on two 3-day trips so far with this vehicle/trailer only an hour from home. Have appointment with Ford this week to check towing setup/etc. With the fridge/pantry in back-keeping in mind we’ve only packed 3 days worth of food for two people-would that be taking weight off the tongue? I can’t compensate for it up front where the Murphy bed is. Wondering if the hitch should be set lower? I haven’t tried towing it empty on the highway.
Old 07-30-2019, 03:40 PM   #5
There are so many things that can cause sway. Already mentioned, uneven load in trailer, incorrect installation of WDH, soft tires, soft suspension. Not enough info to diagnose on this forum without seeing the rig in real life.
I tow with a Dodge 1500 Hemi and had to put in air bag at the rear to firm things up.
Run tire at max cold load when towing on both the TV and the RV.
Iamcanadian is offline   Reply With Quote
Old 07-30-2019, 03:51 PM   #6
Originally Posted by dbackwoods View Post
Itís a square bar e2. Iím getting pulled around even when Iím not around any other vehicles. Weíve been on two 3-day trips so far with this vehicle/trailer only an hour from home. Have appointment with Ford this week to check towing setup/etc. With the fridge/pantry in back-keeping in mind weíve only packed 3 days worth of food for two people-would that be taking weight off the tongue? I canít compensate for it up front where the Murphy bed is. Wondering if the hitch should be set lower? I havenít tried towing it empty on the highway.
Here's something to try.
Inflate your front tires to the suggested pressure for the front axle. Then inflate your rear tires to the MAXIMUM that is molded into the sidewall of the tires. Also, as suggested earlier, inflate trailer tires to max pressure that is shown on the sidewall. (note: make sure you do this when tires are cold like first thing in the morning and use an accurate gauge).
Running two different pressures on the tires of your tow vehicle is an industry wide practice for eliminating (as much as possible) Oversteer. When rear tires are softer than fronts and sidewalls are able to flex more, the rear of the tow vehicle tends to steer the front which creates oversteer. Over steer is when the vehicle changes direction more than what the driver expects when they turn the steering wheel. This is good for racing when the driver wants to hang the rear out on corners (they call this loose).
When you add a trailer to a vehicle the extra tongue weight can cause the rear tires to flex the sidewalls more, side to side, and you get oversteer which can then steer the trailer all over the road.
As long as your front tires are not overloaded for the pressure on the door post (which is often not the case even with WDH hitches) the tow vehicle will be more stable, or at the worst have a slight understeer which is easier to handle and considered far safer than Oversteer.
FWIW, Ford has done this on their pickup trucks for years, recommending different pressures for front and rear. Their front suspension tended to induce oversteer which many drivers complained about. That's why many Ford's had pressures like 44psi front and 80 psi rear.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-30-2019, 04:02 PM   #7
dbackwoods's Avatar
Not sure how to post a pic?
Old 07-30-2019, 04:04 PM   #8
dbackwoods's Avatar
Thanks for the tire pressure advice, I will have that looked at!
Old 07-30-2019, 04:38 PM   #9
bikendan's Avatar
Apparently you are relying on the dealer's setup oh your E2. This is a mistake.
You need to learn how to setup and adjust your WDH yourself.
The dealers are notorious about poor WDH setups, especially because they do it on an empty trailer.
There are lots of E2 setup videos out there and read the manual.
Equalizer WDH
Old 07-30-2019, 04:56 PM   #10
This.This. This.
Many, most?, dealers just eyeball them and get them close.
Watch the video.
Download and print the manual.
Collect the required tools and torque wrench.
Got to the nearest CAT scale and set it up correctly.
Max out your cold tire pressures on the TV and make sure that the trailer tires are at the max cold pressure and see if that helps.
What kind of tires are on the TV? LT (light truck) or passenger tires. I needed to upgrade to a load range E LT tire on my pickup.
Bob
2018 Rockwood Ultra Lite 2902WS Travel Trailer
HappyTrav is offline   Reply With Quote
Old 07-30-2019, 05:54 PM   #11
dbackwoods's Avatar
TV tires are Hankook Dynapro 275/55R20 113T
Old 07-30-2019, 05:58 PM   #12
dbackwoods's Avatar
Just checked TV tire pressure, theyíre at 40psi, max says 51psi.
Old 07-30-2019, 06:02 PM   #13
dbackwoods's Avatar
TT tires are Castlerock ST205/75R14. It says 65 psi cold and tires are at 60 psi now.
Old 07-30-2019, 06:50 PM   #14
The tires are not LT tires they are softer tires that the manufacturer puts on for ride quality and they are cheaper tires also.
I would:
Increase the tire pressures as it will stiffen the tires and that will help some.
Go through the setup of the WDH and weigh at a CAT scale. This is key and minimal cost. It is $12 for an initial weigh and $2 for re-weighs at my local CAT scale.
I would also verify that the tires can carry the weight that is on the axles with some reserve. Higher tire pressures allow the tire to carry more weight but you never exceed the max cold pressure for the tire.
Then I would see how it tows and re-evaluate.
Bob
Old 07-30-2019, 08:51 PM   #15
I tow my 2017 21ds with my Ram 1500 with no issues. I did put Goodyear Endurance tires on the trailer. Tire pressure is very important as is everything else mentioned. Is the rig level? Get your hitch set up correctly and it should make a difference.
2007 Dodge Ram 1500 Hemi
2017 Flagstaff 21ds
WTP2 is offline   Reply With Quote
Old 07-30-2019, 08:59 PM   #16
Platokidd's Avatar
Never have I experience a dealer to set-up wdh correctly.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Old 07-30-2019, 09:02 PM   #17
I have a single axle v cross vibe 6504, it wants to sway looking at it. I have a 2 inch drop hitch on my Ram truck and E2 single sway bar. I was able to cure sway almost 100%, before I did this. Had so much sway was affriad to go over 55, now I can do 75 and feel confident. Here is what I did, zero items behind the axle, I put all weight closest to hitch or all my gear in back of truck. Make sure trailer and truck are level, I seen a single axle trailer on freeway the truck was about 4 inches higher than trailer and could see it sway. By moving everything toward hitch to put weight in truck hitch, I even went through the Dalles in Oregon with 40mph side winds and at 60 mph had no sway to be concerned about.
Rotwiler is offline   Reply With Quote
Old 07-31-2019, 10:39 AM   #18
I have a 2018 21DS and also use the E2 hitch but with the 800 lb bars. Did they give you the 500 lb bars instead? If so, that could contribute to flex. Do you have anything significant stored in the front storage area? Both propane tanks full and one or two batteries?
The CR trailer tires need to be at 65 PSI cold. Always. And watch them carefully!
Post pics of your set up.
I have mine set up at almost perfectly level when loaded and it tows perfect. No sway ever at any speed or any traffic flow.
I was also planning on going to a CAT scale for weighing and was going to ask the question here.
What is the proper procedure for weighing the truck/trailer combination with a WD hitch? Weigh with it installed and then uninstalled? Thanks.
2018 Micro Lite 21DS (New Style Front)
2016 Toyota Tundra Dbl. Cab Limited 4x4 5.7L
sportbikenut is offline   Reply With Quote
Old 07-31-2019, 10:59 AM   #19
Your vehicle appears to be towing at or above specs.
When that occurs you have to be best case everything. Like not so good tires. Maybe too lite bars. Etc.
Personally, the new generation of suvís are not my choice to tow #6,000. Wheelbase is sort of short aggravating this.
Your vehicle was not tested to tow this trailer at this weight. Have to be trained to read SAE specs.
Slow down and work on it.
tomkatb is offline   Reply With Quote
Old 07-31-2019, 11:03 AM   #20
dbackwoods's Avatar
We have the 800lb bars. Both propane tanks are full and 2 batteries. There is nothing significant in the front storage areas, just the grill that came with it and some odds and ends. Behind the axle is the fridge and pantry which is where I probably have weight issues.
sway
