Thetford Aqua Magic Style II White China Bowl Toilet
Last year, we had a problem with the water valve not shutting off completely and experienced an overflow early one morning. To make a long story short, Thedford sent a replacement valve under warranty to Camper Connection in Kissimmee, FL who installed the valve. Watching the tech replace the valve, I questioned him not putting silicone paste lube on it and was told it was not needed. Practically one year to the day later, guess what? TOWTA discovered a near overflow condition again. Got out the silicone spray and sprayed all the outside springs and moving parts. Worked for a couple of days and the foot pedal was very sluggish working. Yesterday I decided to remove the toilet and try my hand at repairing. Lubed everything quite liberally with spray lithium grease and got it working better but not quite right. Decided what the heck. Finally got the pedal off, removed the water valve, lubed liberally with silicone paste lube and re-assembled/re-installed the whole thing. Voila, the pedal worked like new, stopped water flow as intended. Having just about run out of silicone grease, we went to Lowes and bought some more. Taking Herk's suggestion, decided to install a shutoff on the toilet water supply. Not wanting to remove the toilet again, tried installing the valve without removing it. Bad decision. Didn't get the pipe shoved up in the valve far enough and man, 50 psi of pressure puts out a lot of water quickly. Long story shortened somewhat, removed toilet, installed valve properly and everything works great again. Hopefully will never have to use the shutoff valve, but at least it's there if needed.
