Old 01-13-2016, 06:39 AM   #31
craigster_mi's Avatar
Originally Posted by Mr Havercamp View Post
I like that website but the dealer invoice numbers are worthless. I doubt my dealer is selling us a 2016 23WS at a loss. No one, including that website, has a clue what any individual dealers 'Deal" is with a manufacturer.
I totally agree because I paid less than what it calculated as dealer invoice so they obviously got some kind of volume or show pricing but was way less than any other local dealer quoted for the exact same trailer and threw in brake controller and WDH both installed. Like anything on the net you take it with a grain of salt.
craig
2014 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 01-13-2016, 06:32 PM   #32
We bought a 25KS 2 years ago. Had a few problems at first and the TT was in for repairs for a couple of weeks to have warped cabinet doors replaced. All was covered by warranty and the dealer was great to deal with. We like the TT a lot and would definitely buy the same model again.
WildThings is online now   Reply With Quote
Old 02-28-2016, 10:02 AM   #33
run2jc's Avatar
We bought our first camper ever last May, microlite 19fd, we love it we have had it out 8 trips so far and all is well. I love the way it is built all 6 panels are fiberglass I love the quality of the flagstaff. With that said all campers have some problems. I chose to go with an aluminum frame over stick built.
Happy camping!!!
2015 Forest River Micro Lite 19FD.
1999 K1500 Suburban 5.7 ltr 4X4
2002 GMC SIERRA EXT CAB 5.3 ltr 4X4
The Deans Brownsville Texas
run2jc is offline   Reply With Quote
Old 03-23-2016, 07:42 AM   #34
Stevekaz99's Avatar
The 25ks is on order. We hope to get it in 6 to 8 weeks. Thank you all for the help!!!
Stevekaz99 is offline   Reply With Quote
Old 03-23-2016, 05:12 PM   #35
Stevekaz99's Avatar
Forgot to say, I picked it up from a local dealer. It was important to me to have a relationship with the local guy. I can always go to him for help.
2017 Flagstaff Micro Lite 25KS- TT (2016 - ???)
2016 Ram 1500 Crew Cab, 5.7L, 4x4, 3.92
Old 03-23-2016, 10:56 PM   #36
Congrats. We like our Mini Lite 2503S a lot. I added an electrical outlet to the street side sofa "table" for the DW. Also a digital thermostat.
Name:	New outlet 1.jpg
ID:	102667   Click image for larger version
Name:	Water tank drain unpainted.jpg
ID:	102668   Click image for larger version
Name:	Water tank drain painted.jpg
ID:	102669   Click image for larger version
Name:	Digital T-stat 1.jpg
ID:	102670   Click image for larger version
Name:	Digital T-stat 3.jpg
2011 Traverse LT, 3.6L, FWD
Old 03-23-2016, 10:59 PM   #37
Also added a pilot light switch for the electric element of the water heater so I can turn it on/off from inside the bathrom. See pics and wiring diagram.
ID:	102672   Click image for larger version
ID:	102673   Click image for larger version
ID:	102674   Click image for larger version
Old 03-30-2016, 11:46 AM   #38
Stevekaz99's Avatar
rockfordroo, Great mods.
What was the main advantage to replacing the digital thermostat? Also was it difficult? A number of years ago I replaced the one in my home so I have experience with that. Are the wires the same?
Old 03-30-2016, 12:15 PM   #39
Digital thermostat controls temp a LOT better than the analogs. I replaced a Coleman Mach analog with the $20 Honeywell. If you want to spend a bit more, they make a Coleman Mach digital ($53 on Amazon: Robot Check). It's a direct plug and play.
The Honeywell will only run one fan speed - pick whichever you one you want; however, you can install a switch to allow you to change fan speeds. I installed one inside the T-stat, but you could also install an RV type rocker switch like this one, JR Products On/On Switch, Black SPDT 12625, in the wall next to the T-stat, which I've been thinking of doing.
I've attached some additional pics showing the switch I installed and a wiring diagram. You have to carve out some of the plastic on the inside to make room for the switch.
ID:	103318   Click image for larger version
ID:	103319   Click image for larger version
Old 03-30-2016, 12:52 PM   #40
Stevekaz99's Avatar
rockfordroo, I like the idea of plug and play with the Coleman Mach digital. will look at that. Thanks!!
flagstaff
