Old 08-14-2006, 10:43 PM   #1
Wink Thinking of switching
I have posted this on RV.net, but I wanted to come to this Forum since it has link to just Flagstaff. So here goes, Anyone have a FS 831BHSS? and if so what are you towing with. I have a FS 27BHSS right now and I am towing with a 06 Chev Avalanche, 5.3L V8, 3.42, Heavy Duty Towing Package. Anyone think it will be too much TT for the Avalanche by stepping up to a 831BHSS? Thanks. Those of you on this forum that responded on RV.net thanks for the replies!!!!
CampDetective is offline   Reply With Quote
Old 08-15-2006, 07:21 PM   #2
Bear's Avatar
What is the actual weight of the trailer? What is the pin weight of the trailer? What is the MCGVW of the Avalanch? What is the actual GVW of the Avalanch? What are the allowable weights of the Avalanch (they are on a sticker on the door frame of drivers door)? Sorry for all the questions but I need this info to make an informed reply. Take the truck to a scale and weigh it with full fuel and yourself. Then take the trailer and weigh it full of the stuff you want to take with you. It is a PITA but that is the only way to see if you will be within your weights. Never trust the weights published on a trailer, they are always wrong.
Cheers
Bear
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 10-23-2007, 06:02 PM   #3
cmprguy's Avatar
Hi. I have a 831krss. my tow vehicle is a 2005 silverado 1500 4x4 5.3 no problems! i did install a air bag susp. on the truck to help out. it`s an ultra light trailer. if they say 6500 is ultra light! but the truck is rated for arount 8000 tow.
cmprguy is offline   Reply With Quote
Old 10-23-2007, 10:04 PM   #4
welshman599's Avatar
Send a message via MSN to welshman599
You know, at first, the topic "thinking of switching" had me wondering if I was on the right forum.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 10-24-2007, 07:31 AM   #5
Hi CampDetective,
I have added a link to another site for Avalanches. It has all the info you could ever want to know about the towing capacities of the Avalanche.
WHAT IS TOW HAUL?
Avalanche comes with a four-speed automatic transmission with overdrive and Tow/Haul mode. When activated, Tow/Haul mode reprograms the automatic transmission to reduce the frequency of gear shifts when towing. SOURCE: The General.
WHERE IS MY WIRNING HARNESS FOR MY BRAKE CONTROLLER?
Chevrolet no longer provides you with a wiring harness for you brake controller. They do not provide the 40 amp fuse or the 7 to 4 wire adapter for the wiring connector. 2003 model.
SO HOW MUCH CAN I TOW?
Trailer towing 1500 2WD 1500 4x4 2500 4x4
3.73 axle ratio (lbs.) 7200 7000 9,900
4.10 axle ratio (lbs.) 8200 7900 11,900
Maximum trailer weight ratings are calculated assuming a base vehicle, except for any option(s) necessary to achieve the rating, plus driver. The weight of other optional equipment, passengers and cargo will reduce the maximum trailer weight your vehicle can tow.
SOURCE: Then General.
Here are some general rules of thumb, these have been based on the Insurance industry reviews after accidents, as with all rules of thumb your situation may not apply but they are a good reference.
Tongue Weight Rule of Thumb
Tongue weight = 10% to 15% of actual loaded trailer weight.
Trailer Weight Rule of Thumb
Maximum trailer weight being towed...should only be 75% of the weight rating of your tow vehicle. (CGWR being taken into consideration). If factory rating is 5,000 lbs. trailer,... a 3750 lb. trailer weight is recommended, etc. If 7,000 lb. trailer is stated,...a 5250 lbs. trailer weight is recommended, etc.
Weight Distribution Hitch Rule of Thumb.
When tongue weight approaches 350 lbs.,...a weight distribution hitch system is recommended.
Wheel Base Rule of Thumb
A tow vehicle should have a minimum wheel base of 100 inches. A wheel base of 110 inches is recommended for a 20 foot trailer. For every additional foot of trailer length (above 20') add 4 inches to the wheel base. i.e., a 22 foot trailer=118 inches wheel base, a 24 foot trailer=126 inches wheel base. Etc. However, when you get into the larger, full size tow vehicles, such as Av's, Surburban's, F-150's, Ram Trucks, etc. this rule relaxes, as these types of vehicles (if properly set up) are capable of towing much larger trailers than this rule would suggest.
http://www.chevyavalanchefanclub.com...oard,19.0.html
~Wags
Wags is offline   Reply With Quote
Old 04-11-2010, 12:13 PM   #6
Hello: I've read your post and thought I'd put my 2cents. My brother had a flagstaff TT 30ft. Liteweight. He pulls it with an 08 Yukon Denali with the big V8 engine. I think it's a 8.0 ltr. Anyway, we been camping with them for a couple of years and it pulls the TT pretty well. According to him, it gets a bit sluggish going up steep grades and has to slow down. And his MPG isn't all that great, between 8-10MPG. I have a 30ft 5er Flagstaff and pull it with an 07 Chev 2500hd DA and don't have a problem but I do have to slow down to let him keep up with me. I don't drive over 65mph, usually 60mph for safety as well and gas mileage. As I said he doesn't have a problem. Just wanted to let you know.
Happy trails...
TWO4THEROAD is offline   Reply With Quote
Old 04-11-2010, 07:56 PM   #7
Dave_Monica's Avatar
Man, blow the dust off of this thread!
I know you're new to the forum and I only encourage you to post, but please don't pull up threads that are 3+ years old. If there' something that interest's you from an old thread, start an entirely new thread and people will respond to it.
Thanks,
Dave
flagstaff
