Old 04-02-2018, 03:56 PM   #1
OswegoLion's Avatar
Tire pressure question?
I just replaced my tires with a 10 ply tire max pressure is 80 lbs. My original were 8 ply. On my 5th wheel the label on tire pressure says 60 lbs. Which directions do I follow?
OswegoLion is offline   Reply With Quote
Old 04-03-2018, 07:55 AM   #2
SeaDog's Avatar
Follow the pressure listed on the sidewall of the tire.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-03-2018, 08:11 AM   #3
There are MANY opinions on this subject.
Many say to just pump it up and use the MAX pressure listed on the tire.
I tend to follow the tire manufacturers recommendations of adjusting the pressure for the amount of load on the tire.
You didn't mention the brand but most tire manufacturers have a chart with guidelines of recommended pressures for a given load.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 04-03-2018, 08:29 AM   #4
OswegoLion's Avatar
Iím getting 2 different opinions!! I will need to continue research! Big difference between 60 and 80 lbs.
Old 04-03-2018, 09:12 AM   #5
SeaDog's Avatar
Something to consider is the label in the rig is for the tires supplied. If you are running different ST tires the Mfgs say air to sidewall pressure.
Retired Navy
Old 04-03-2018, 09:16 AM   #6
Air? Air in tires is over rated. Lowest possible pressure should give you the handling and ride you need. Soft and cushy. This is for you. Lowering Kit - $19.95 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
vmax is offline   Reply With Quote
Old 04-03-2018, 09:32 AM   #7
Fulltime family RVer
(Sigh.) Why be snotty? The OP didnít ask anything about a cushy ride.
Itís a legit question- the sticker on the camper was issued by federal regulation by the manufacturer.
The tires are stamped by their own regulations.
Both are official and we have had tire experts proclaim that each should be used.
Have you ever considered just avoiding tire pressure posts? They seem to get you riled up.
Old 04-03-2018, 09:54 AM   #8
(Sigh.) Why be snotty? The OP didn’t ask anything about a cushy ride.
It’s a legit question- the sticker on the camper was issued by federal regulation by the manufacturer.
Take it easy I'm trying to hit that 16,xxx post mark like you.
Old 04-03-2018, 10:05 AM   #9
Retired TrackWalker
ForestWalker's Avatar
My tires seem to prefer the 8d size.
2017 Forester
3051S "Bluga"
ForestWalker is offline   Reply With Quote
Old 04-03-2018, 10:08 AM   #10
+++++1
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-03-2018, 10:28 AM   #11
I trust the tire markings over the trailer markings.
The trailer manufacturer has no idea what tires you are replacing the originals with. Their markings are based on the trailer with original tires.
As long as the tire is sufficient to handle the load of the trailer, the tire manufacture has taken into consideration the trailer that sits on the tire.
As far as changing loads go, as long as they are within the rating of the tire, tires automatically adjust according to the load, putting more or less footprint on the ground based upon the load.
eye95 is offline   Reply With Quote
Old 04-03-2018, 11:13 AM   #12
frostriver's Avatar
If you bought Maxxis tires, follow the chart on this link:
http://international.maxxis.com/trai...nflation-chart
frostriver is offline   Reply With Quote
Old 04-03-2018, 11:41 AM   #13
Commercial Member
Response from a tire design engineer to the posts in this thread.
- Suggest that people read THIS thread
as it asked the same question.
- Pressure on the tire sidewall is the minimum pressure needed to support the load number molded on the tire sidewall. The GAWR on the TT certification lable is the important number that should not be exceeded.
- For all intents and purposes all tire companies have the same information in their Load & Inflation tables.
- Lowest possible pressure will result in shortest tire life.
- If you load the TT to the LR-E tire spec you will be overloading the axles which is not safe.
It is clear that many have not read THIS thread.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA in Tuscon, AZ and Syracuse NY in 2020
Tireman9 is offline   Reply With Quote
pressure, tire
