Old 08-06-2018, 12:23 PM   #1
Bozo2017's Avatar
Tire question for Flagstaff Owners.
Question. Anyone with a Flagstaff 25fks installed 215 75 14 in. Tires in place of 205 75 14
Bozo2017 is offline   Reply With Quote
Old 08-07-2018, 06:39 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. If your FKS is like mine your axles are very close together you gain 1/2 in width and 1/2 in height with the 215 which means you are putting the tires closer together. Both come in C and D ratings. Why not keep the spacing and upgrade the 205s to D rating. If you are only traveling on paved roads and improved campgrounds then spacing may not be an issue.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 08-07-2018, 07:05 AM   #3
Bozo2017's Avatar
Thank you SeaDog
Old 08-07-2018, 07:09 AM   #4
jeff64's Avatar
I stayed with the same size 205-75-R14 in an GY Endurance D rated. Mine has barely 2 fingers between them and would certainly not ever want to experience an instance where that distance suddenly decreased for any reason. JMO
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-07-2018, 07:23 AM   #5
Bozo2017's Avatar
Thank You jeff64 I guess everyone can tell I am new at this this is very helpful
Old 08-08-2018, 05:21 PM   #6
Tundra 2014
tires
I had the same concern. We have a Flagstaff Emerald 27VRL, I upgraded from 205s-C to 14" 215/75-D. In the GY Endurance chart, the diameter is the same as 205s. I had 2 3/4" prior and is now is the same, maybe 1/16" less.. Mine is a 2016, next model year they went to 15" tires. What ever you switch to, be very careful where they put the jack! They put a jack under the rear support bar, behind the rear axle and bent it. That bar is Thin metal, had to cut out and weld heaver square tube under trailer. I was using an Anderson drive on tire changer to allow the tire shop, Sams Wholesale, To change a tire at a time. Turned my back on them, 1 minute-GEE. After I bought tires and paid on line they told me they do not install on trailers, AUGH!
Tundra 2014 is offline   Reply With Quote
Old 08-08-2018, 05:48 PM   #7
I briefly considered this for my 233s. Space between the tires convinced me not to. Got rid of the Constancys and mounted new Goodyear Endurance 205s with metal stems and a TST TPMS 507 system.
My17Ram is offline   Reply With Quote
Old 08-22-2018, 02:29 PM   #8
I have the same trailer and installed the same tires. Went from 205 to 215 with no issue. Like said, lost maybe like 1/8" between the tires. The different in towing was night and day over the spongy china bombs it came with.
2017 Ram 1500 Sport 5.7
2015 Flagstaff 27VRL
Riccochet is offline   Reply With Quote
Old 08-22-2018, 03:04 PM   #9
Tundra 2014
I agree. Much better towing w/o bounce.
