Old 06-04-2014, 12:23 PM   #1
Citrus County, Fl.
GL1800Rider's Avatar
Tire Valves - rubber or metal
I have a Flagstaff Classic super lite on order and would like to know if any recent purchasers can tell me if the tire valves on these or the Rockwood Signature Ultra Lite are rubber or metal. I am in the process of purchasing a tpms system and understand the flow thru transmitter is a bit too heavy for the rubber valves.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 06-04-2014, 12:33 PM   #2
Our Classic is a 2011. It came with rubber valve stems and I would be surprised if that has changed. I replaced the tires with load range E Maxxis and at same time installed TST 507 system and changed to metal stems. No problems and less worries. I hope you enjoy your "Falstaff" as much as we have enjoyed ours.
Paul & Anne
2011 Flagstaff 831RLSS
2013 F150 SuperCrew Lariat 4x4 3.5L EcoBoost Max Tow 157"wb
Husky Centerline Hitch
hokiecampers is offline   Reply With Quote
Old 06-04-2014, 12:38 PM   #3
wyo700's Avatar
Can pretty much guarantee it will come with rubber valve stems.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 06-04-2014, 03:11 PM   #4
2014 rubber on flagstaff, with green caps = Nitrogen-filled tires
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 06-04-2014, 06:03 PM   #5
Citrus County, Fl.
Thanks for the input. I figured they would most likely be rubber so will order the tpms with the removable caps
Sent from my SCH-I545 using Forest River Forums mobile app
99 Terry 31G
Old 06-04-2014, 06:12 PM   #6
MtnGuy's Avatar
Regardless if you flow through or non-flow through, if you put any kind of TPMS sensor on the valve stems, it is probably best to get metal valve stems installed. A tire shop can do that fairly simply.
Old 06-04-2014, 08:11 PM   #7
Citrus County, Fl.
Good point, it's bad enough the come with load range D tires.
99 Terry 31G
Old 06-04-2014, 08:19 PM   #8
Herk7769's Avatar
Load range C tires come with rubber stems. If you go to load range D you should get metal "high pressure" stems and if you got to load range E you must get them.
HAM CALLSIGN - KC3FFW
tire, valve
