Old 05-26-2009, 09:47 PM   #1
Chris and Sara
toggle switches 829 FKSS
I have three switches under my microwave. One is for the slide out, one is for the right side scare light. Anyone know what the third one is for? I turned it on and off several times, but nothing seems to be controlled by it!! Thanks
2004 F-150 with Tow Package
2009 Flagstaff 829 FKSS
Prodigy Brake Controller
Equalizer Hitch
renegaderailfan is offline   Reply With Quote
Old 05-27-2009, 05:47 AM   #2
I have two scare lights, one on the front and one on the the back side of the camper and they are on separate switches. Turn the switch on again and then go out side and walk around the camper. You can also see if it control the out side orange light by the door.
Old 05-27-2009, 08:28 AM   #3
Do you have a step light That is what my turns on. There is a little fixture on the right side of the front step i bet that is what it is for
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 05-27-2009, 07:35 PM   #4
Don and Elaine's Avatar
Chevy 02 is probably right, the 3rd switch in my 831FKBSS is for my outside step light, hard to see by day but try around dusk to see if the switch controls that light.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017, and 94 days in 2018.
Don and Elaine is offline   Reply With Quote
Old 05-27-2009, 10:11 PM   #5
Chris and Sara
good deal, I will check it out!! Thanks guys
Equalizer Hitch
flagstaff
