Easy to pull, just shut the water off, disconnect the water line, remove two nuts on base and lift it off. We stuff a couple of washclothes in a plastic bag and stick in the hole to prevent smell and possibly dropping something in the black tank. You need to determine if the leak is from the water inlet to the toilet before you remove it. Might want to wear the disposable gloves also.
