Old 09-16-2012, 09:24 PM   #11
Timex's Avatar
And hopefully the stink bugs!
Timex is offline   Reply With Quote
Old 09-16-2012, 09:47 PM   #12
VinceU's Avatar
Wow I guess the way it was, the only vent for expanding gases was the
W. C. itself eh? Good find!
VinceU is online now   Reply With Quote
Old 09-16-2012, 11:09 PM   #13
jimh's Avatar
u don't want it below that hole it is pushed thru on the vent. keep in mind when u start cutting, that pipe moves as u go down the road.
jimh is offline   Reply With Quote
Old 09-16-2012, 11:50 PM   #14
2011 Berkshire 390BH
Superchief's Avatar
Be careful how much you cut off, if any. I recently decided to install a cyclone type sewer vent device on the vent tubes on my Unit. In one case I had enough pipe extended to attach the device. In the case of the other vent, it was cut at an angle and I could not attach the device. They had cut the front flush with the top of the cover. I ended up trimming the outside cover so that I could expose enough vent pipe to connect to. I then had to caulk the entire base, as soon as I stabilized the vent pipe inside the cover.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 09-17-2012, 03:39 PM   #15
Timex's Avatar
I'll giver the hacksaw boogie here in a day or so. I'll take some more pics to compare with the beginning point.
Old 09-17-2012, 03:57 PM   #16
VinceU's Avatar
Just to clarify you should cut 1/2" down on the existing black pipe. This will leave you with 1/2" gap below the rain cap, thats what you want. You should probably mark you line all the way around and use a sawzall or dremiel cutter to get a decent cut. A hanksaw may have problems with the seal fitting.
Old 09-17-2012, 04:32 PM   #17
Timex's Avatar
Do you mean not having enough room to use a hacksaw?
I'm sure I'll have to sand the burrs of the cut.
Old 09-17-2012, 05:15 PM   #18
MtnGuy's Avatar
You want a little sitting above the pipe in case you want to add a rotating vent system later on. I think you need 1/2" for some of those models.
Old 09-17-2012, 08:02 PM   #19
VinceU's Avatar
Yes, cause of the two cap retainers sticking up alongside the vent.
Old 09-17-2012, 08:13 PM   #20
Timex's Avatar
Going back and looking at my pics, I see what you mean. Dummy me I'd probably cut them off too!
