Old 09-17-2012, 09:05 PM   #21
DDC
DDC's Avatar
That pipe moves up and down as the tank fills or empties, remember it is attached to a plastic tank and the top of the tank moves up or down.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-17-2012, 09:17 PM   #22
VinceU's Avatar
Thats correct, that white fitting is actually a sealed expansion joint. The pipe can't move very far however, it would have popped his top cap! Besides the tank will crack if it moves very far repeatably.
Old 09-17-2012, 09:36 PM   #23
DDC
DDC's Avatar
That's how I learned this I had a Sunnybrook and the cap popped of, the pipe was about half an inch too long.
Old 09-17-2012, 10:12 PM   #24
Timex's Avatar
Ok, help me understand.
The black pipe actually moves up/down?
Is it attached to the tank itself?
And why would the tank move up/down as it fills/empties?
Is it not strapped down to the frame?
If I cut off too much pipe, what would happen?
Timex is offline   Reply With Quote
Old 09-18-2012, 07:22 AM   #25
DDC
DDC's Avatar
The tank has a large surface area and it's plastic, the pipe is attached to the top of the tank and as we all know plastic is pliable so the pipe moves.
Old 09-18-2012, 07:32 AM   #26
Mine is glued to the roof flange and the vent cap is screwed to the pipe. It may move, but only if the roof is flexing. The top of the pipe is flush with the bottom of the vent cap.
Old 09-18-2012, 10:15 AM   #27
Timex's Avatar
My vent cap has one screw that holds it to the roof flange along with 3 push down snaps. Don't know, but I would think there would be some caulking under the roof flange that would also be around the pipe. The pipe cannot be turned by hand so I tend to believe it won't move up/down either. It is not secured at the top, so it must be at the tank.
ID:	19639   Click image for larger version
ID:	19640   Click image for larger version
Old 09-18-2012, 11:39 AM   #28
BeagleIL's Avatar
Maybe I missed it along the way - but what makes you think that your black tank isn't venting properly?
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
Old 09-18-2012, 02:11 PM   #29
Timex's Avatar
Da stank! Done everything else.
Old 09-18-2012, 02:17 PM   #30
BeagleIL's Avatar
Even if my vent pipe was completely blocked, the only time any odors would get into the cabin of my trailer would be when the toilet gets flushed. And that would be for just a few seconds of having the flush valve open. Other than that, I don't see how you would get odors into the trailer.
Does your toilet hold water in or does it seep into the tank over time?
