04-23-2019, 02:50 PM
Tongue Jack has no power
Just returned from a trip with our 29 RSWS. Great trip with no problems. Except that when we got home and went to disconnect the trailer from the truck, the automatic tongue jack had no power. The trailer itself did, as the outside lights still worked, but the jack itself and the LED lights on the jack did not. Any ideas why that would lose power? We ended up manually cranking it.
04-23-2019, 02:52 PM
Is there a fuse in the line for the jack? It may be next to the battery.
04-23-2019, 02:55 PM
Every electric tongue jack I've seen, has an inline fuse.
04-23-2019, 02:57 PM
Yep fused or 12v circuit breaker.
Have you checked at the jack for 12v?
04-23-2019, 03:16 PM
The switch itself sometimes goes bad. Will often go up, but not down, or vice versa. Check the fuse first but if it is good check the switch.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
04-23-2019, 03:18 PM
Just as confused as you
You may have to remove the housing on the jack. My jack has a fuse inside the housing.
Richard & Jill
04-23-2019, 04:54 PM
I have had more problems with the mounting bolts being very slightly rusted which results in a bad ground. Try loosening the bolts and then resnug them. I had a problem with this on two TT. the only ground is through the mounting bolts.
04-24-2019, 01:41 PM
Tongue jack no power
Bad ground
04-24-2019, 02:30 PM
Is it a Smart Jack? How old? Our brand new one was under recall but hadn't been replaced. Found out the hard way at a CG around 5 in the morning during a heavy rain when the TT started going up and down. Then it just died.
2018 Rockwood Signature Ultra Lite 8311WS
2014 Coachmen Apex 215RBK
2018 GMC Sierra 2500HD SLT Duramax
04-24-2019, 02:55 PM
I've had this happen twice now. Mine has an inline mini-fuse in the wire coming from the trailer to the tongue. Both times pulled the fuse, looked fine but would not allow power to the jack. Replaced the fuse both times and the jack worked as usual...go figure...
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
04-24-2019, 04:26 PM
We had a similar Problem
The fuse for our jack was inline just above the hitch frame. The fuse is in a retangular thin rubberish holder whose top pulls off. Our fuse was blown and needed to be replaced. After it was replaced the jack wouldn't go down at all. It would make noises like like it was trying. From reading the forums I gathered these tibits of jack wisdom.
1) If you bring the jack too far up (like at or past the red line) it will blow the inline fuse.
2) If you extend the jack down too far (as in trying to take the pressure of the bars of your Husky Load Bearing Hitch), you risk breaking the gears and stuff that allows the electric motor to go up/down.
I used the manual cranks to "free" the jack and the electric motor would move the jack up/down about 6" that is all. So I had to manually crank it the rest of the way.
I called the dealer April 22nd and my service appointment is May 30th.
What I wonder is if I should buy a new Barker or Huskey jack which i hear have steel bits inside that won't break?
The Cahoons, Tim & Nancy
2019 235S Rockwood ROO (1st Time RVrs)
(end of year sale model, new unit)
04-24-2019, 04:28 PM
you can not check a fuse by looking at it.
04-24-2019, 10:47 PM
Jack fuse
On my Flagstaff it is in a green plastic fuse holder 2' back in the "A" frame behind the battery. I have a fuse for my front slide also, next to the jack fuse. We found that if we operated these 2 things at once, it blows this fuse. Our error, they do not need to be done @ the same time.
