Old 04-23-2019, 02:50 PM   #1
timmyd's Avatar
Tongue Jack has no power
Just returned from a trip with our 29 RSWS. Great trip with no problems. Except that when we got home and went to disconnect the trailer from the truck, the automatic tongue jack had no power. The trailer itself did, as the outside lights still worked, but the jack itself and the LED lights on the jack did not. Any ideas why that would lose power? We ended up manually cranking it.
timmyd is offline   Reply With Quote
Old 04-23-2019, 02:52 PM   #2
Is there a fuse in the line for the jack? It may be next to the battery.
spydunks is offline   Reply With Quote
Old 04-23-2019, 02:55 PM   #3
bikendan's Avatar
Every electric tongue jack I've seen, has an inline fuse.
Equalizer WDH
Old 04-23-2019, 02:57 PM   #4
Yep fused or 12v circuit breaker.
Have you checked at the jack for 12v?
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 04-23-2019, 03:16 PM   #5
The switch itself sometimes goes bad. Will often go up, but not down, or vice versa. Check the fuse first but if it is good check the switch.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 04-23-2019, 03:18 PM   #6
Just as confused as you
Scrapper's Avatar
You may have to remove the housing on the jack. My jack has a fuse inside the housing.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 04-23-2019, 04:54 PM   #7
I have had more problems with the mounting bolts being very slightly rusted which results in a bad ground. Try loosening the bolts and then resnug them. I had a problem with this on two TT. the only ground is through the mounting bolts.
BarabooBob is offline   Reply With Quote
Old 04-24-2019, 01:41 PM   #8
Tongue jack no power
Bad ground
johnlochbuie is offline   Reply With Quote
Old 04-24-2019, 02:30 PM   #9
Is it a Smart Jack? How old? Our brand new one was under recall but hadn't been replaced. Found out the hard way at a CG around 5 in the morning during a heavy rain when the TT started going up and down. Then it just died.
2018 Rockwood Signature Ultra Lite 8311WS
Chazman is offline   Reply With Quote
Old 04-24-2019, 02:55 PM   #10
I've had this happen twice now. Mine has an inline mini-fuse in the wire coming from the trailer to the tongue. Both times pulled the fuse, looked fine but would not allow power to the jack. Replaced the fuse both times and the jack worked as usual...go figure...
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
power
