10-24-2015, 05:32 AM
Torque and Nitrogen
I'm going to ask 2 simple questions for the vets. How much torque on lug nuts? I believe lug nuts are 1/2"?
Also tires have nitrogen in them where do I go if I need to add air?
Thanks for all your help.
Taking our 2 nd trip and going to Silver Palms for 4 days.
10-24-2015, 05:39 AM
Are your Rims Steel or Alum? Have you removed them or torqued them before? Youroo!! Use Air to inflate!
10-24-2015, 05:51 AM
Normal torque on a 1/2" stud is 90lb/ft to 120lb/ft. I shoot for 105lb/ft - 110lb/ft regardless of whether it is steel or alum. Steel wheels usually will stay torqued with one tightening to set, whereas alum wheels will take 2-3 tightening's to be set.
10-24-2015, 06:26 AM
Just do a search on the keyword Nitrogen and you'll have enough to read over the winter.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
10-24-2015, 06:54 AM
Nitrogen
I once pulled into a Tire Shop to get a tire aired up.The guy tried to sell me on having all 4 tires filled with Nitrogen, for 20 bucks a tire. I told him, I got 80% Nitrogen in them now, for free.
His reply?
"Uhhh, Where'd ya get that?"
10-24-2015, 07:16 AM
I check my pressure once a year, in fact it has not changed in 16 months since I put new tires on with rubber valve stems, no TPMS and Nitrogen.
B and B
10-24-2015, 07:21 AM
I use a 4 way with my 53 yr old 230lb rear end behind it. I use it before I hit the road and spot check them at every stop. After having the wheels off for anything I check them at 10/25/50 and spot check at every whiz stop, which is more often the older I get. I have never lost a wheel and I have towed a few trailers a few miles. Take your trailer for a safety inspection, brakes, or new tires, and I'll bet you a torque wrench (Snap on or Cornwell, not a HF Pittsburgh pro) that the guy grabbed his trusty impact gun and left them (your nuts) have it. Ask him specifically if they used a torque wrench they'll say "sure did"......they didn't.
It amuses me when people run out and buy a torque wrench at Harbor Freight or Northern China Tool. If that makes you feel better and safer go ahead. Its your money. There is no telling how many lbs/ft theyre getting them to but they feel better. I prefer to spend my money on beer.
Nitrogen? Take a heat gun and peel the advertisement off the side of the trailer.
10-24-2015, 07:28 AM
Georgia Rally Coordinator
For get the Nitro. I got rid of it in my tires. I have to check lugs every so often as it seems the Aluminum will never stay tight. Check air every trip and yep the aluminum seems to want to loose a little. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
10-24-2015, 07:30 AM
Most Tire Shops use (Torque Sticks) rite or wrong that is what they use! I use My (SnapOn T/R)! Youroo!!
10-24-2015, 07:59 AM
I torque my wheels at 100 #' and always keep 78% nitrogen in all five tires.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
10-24-2015, 08:34 AM
That is just untrue. When they replaced my tires they used the air gun, then asked me what torque do I want on them. The Second time they pulled them to install metal stems the same thing was done and asked. I watched them use the Torque wrench. How are you supposed to know the Torque with out one? You can use it on a lot more then just lug nuts. I guess you do it by feel, well good luck with that one, I'll be the fool that buy's it for $21.00 bucks, link attached. one... http://www.harborfreight.com/media/c...mage_24093.jpg
Coachmen M/H
Concord
2018 / 300 DSC
10-24-2015, 08:58 AM
Mine is an old Craftsman beam style.
You can still buy them at Sears for $23.
10-24-2015, 09:00 AM
I try to keep 78% Nitrogen in my tires but I have been having a hard time finding an affordable gauge that allows me to measure the percentage. I certainly don't want to get it wrong.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
10-24-2015, 09:12 AM
At least they are better than nothing! My tire shop uses a regular torque wrench.
B and B
10-24-2015, 09:27 AM
I carry and use a Williams torque wrench calibrated @ Lockheed Martin when I worked there. Calibration has long since expired, but I have 2 other Williams torque wrenches, 1 is a beam style and one a click/sight and they all check within about 5# of each other. I wouldn't trust one from Harbor Freight to be accurate or one from Northern Tool unless it was a brand name.
10-24-2015, 09:53 AM
That is just untrue. When they replaced my tires they used the air gun, then asked me what torque do I want on them. The Second time they pulled them to install metal stems the same thing was done and asked. I watched them use the Torque wrench. How are you supposed to know the Torque with out one? You can use it on a lot more then just lug nuts. I guess you do it by feel, well good luck with that one.
Glad you found a good shop that actually does it that way. The vast majority do not and that includes car dealers, RV dealers, Tire dealers, mechanics. Hang on to those guys because ones you can trust are few and far between.
I use a torque wrench on head gaskets and bearing caps....not so much on lug nuts. I can tell when a lug nut is tight or not.
10-24-2015, 09:59 AM
OC I think that Pittsburg is good wrench for the money, much better then trying to feel the Torque.1/2 in. Drive Click Type Torque Wrench
"Impressive accuracy, amazing value."
Car Craft Magazine I bought mine at Napa thats what they sell....I know it might not be up to Lockheed Martin standards, but knew that buying it at Napa. Also life time warranty. At least I will be closer then feel. After Goodyear did my lugs, I tested mine and it clicked. I do understand your point...
Coachmen M/H
Concord
2018 / 300 DSC
10-24-2015, 10:00 AM
... I can tell when a lug nut is tight or not.
How can you tell the studs are at 75% proof load vs 50% or 90%?
10-24-2015, 10:12 AM
Should be ok, mine was just calibrated @ LM, LM uses different brand name torque wrenches, but they all had to be calibrated to MIL-STD-45662A when I was doing quality system audits, I think it is ISO 17025 now.
10-29-2015, 03:25 PM
I bought a Northern Tool TW in a pinch before. Standard 1/2" clicker style. Surprisingly it's about 5# off from my SnapOn. Stays in my trail tool kit when off-roading.
My local tire shop will spin lugs on with an impact set at around 50# then torque to spec by hand. Beats wrenching each nut on by hand.
2020 Ram 2500 Laramie Longhorn 6.4
2015 Flagstaff 27VRL
